summaryrefslogtreecommitdiff
path: root/ChangeLog (unfollow)
AgeCommit message (Collapse)Author
2009-02-062009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* aclocal/canonical-target-name.m4: Remove comment referring to HPUX9.
2009-02-052009-02-05 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Remove pck6 BSP.
2008-12-312008-12-31 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* config-ml.in: Comment out arm/thumb exception (Add arm/thumb multilib).
2008-12-302008-12-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* aclocal/check-bsps.m4: remove stray ")" from rtl22xx_t alias.
2008-12-222008-12-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* aclocal/canonical-target-name.m4: Remove tic4x.
2008-12-042008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi>Joel Sherrill
* README.configure: Add Lattice Mico32 support.
2008-10-142008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add h8sxsim as variant of h8sim.
2008-10-022008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* README.configure: Add new M32R port. It is just a beginning but the BSP is functional enough to initialize and shutdown RTEMS.
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add M32C port and m32csim BSP.
2008-10-012008-10-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* VERSION: Bump version to 4.9.99.0
2008-10-012008-10-01 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
PR 1324/bsps * aclocal/check-bsps.m4: Revert Joel's icecube patch.
2008-09-292008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* MAINTAINERS: Remove myself from avr.
2008-09-252008-09-25 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Recognize the the GDB SuperH simulator is just an architectural simulator and does not include devices. Rename existing simulator BSP configurations to simsh1 and simsh2 and add simsh4.
2008-09-242008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org>Joel Sherrill
PR 1324/bsps * aclocal/check-bsps.m4: Add missing icecube.
2008-09-222008-09-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* aclocal/version.m4: Bump RTEMS_API to 4.10. Bump _RTEMS_VERSION to 4.9.99.0.
2008-09-22added BSP for ARM LPC24xxThomas Doerfler
2008-09-092008-09-09 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* README.configure: Updated list of BSPs.
2008-09-08added new BSP for powerpc/tqm8xx boardsThomas Doerfler
2008-09-05Remove bogus entry.Joel Sherrill
2008-08-152008-08-15 Allan Hessenflow <allanh@kallisti.com>Joel Sherrill
* src/lib/libbsp/mips/jmr3904/tools/runtest: Add bf537Stamp.
2008-07-272008-07-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* acinclude.m4 (_RTEMS_OUTPUT_SUBDIRS): Allow empty configdirs.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Remove doxygen comments. * aclocal/rtems-top.m4: Require AC_DISABLE_OPTION_CHECKING. AC_PREREQ(2.62).
2008-07-14updated gen83xx BSPThomas Doerfler
updated haleakala BSP added MPC55xx BSP
2008-07-14added haleakala BSP contributed by Michael HamelThomas Doerfler
2008-07-11added BSP to m68kThomas Doerfler
adapted PPC exception code
2008-06-012008-06-01 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* configure.ac, acinclude.m4: s/AC_HELP/AS_HELP/.
2008-04-142008-04-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* bootstrap: Use find . ... preinstall.am for portability reasons.
2008-02-202008-02-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* aclocal/enable-cxx.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4, aclocal/enable-tests.m4, aclocal/multilib.m4: s/AC_HELP/AS_HELP/.
2007-11-062007-11-06 Ray Xu <rayx.cn@gmail.com>Joel Sherrill
2007-09-212007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* VERSION: Bump VERSION to 4.8.99.0.
* aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0.
2007-09-042007-09-04 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill
* Makefile.maint: touch all documentation master files so the date on the manual reflects the release date of the software.
2007-08-072007-08-07 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill
* Makefile.maint: Add touching master files for various manuals so the date on the cover page will reflect the date a tarball is cut.
2007-08-062007-08-06 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill
* README.configure, aclocal/bsp-alias.m4: Rename EP5200 to IceCube since that is the nickname for the Freescale evaluation board it is based upon. BSP was tested on a Freescale MPC5200LITE.
2007-08-022007-08-02 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill
* Makefile.maint, configure.ac, release_support: Remove RDBG. * aclocal/enable-rdbg.m4: Removed.
2007-07-10compilable release of virtex/gen83xx/gen5200 powerpc adaptations. Merged ↵Thomas Doerfler
many different versions of new exception handling code to shared sources.
2007-07-04merged individual exception handler code to a common one.Thomas Doerfler
2007-06-202007-06-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* aclocal/bsp-alias.m4, README.configure: Add ep5200, IceCube, 5200Lite.
2007-06-122007-06-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill
* README.configure: Removed armulator.
2007-05-152007-05-15 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill
* README.configure, aclocal/check-bsps.m4: Remove references to mbx860_1b since it is just an alternate name for the mbx860_001b.
2007-05-112007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Per Jiri Gaisler remove unused erc32nfp and leon1 BSP variants.
2007-05-112007-05-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* README.configure: DMV152 obsoleted.
2007-02-212007-02-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* Makefile.maint: Added TOOL_VERSIONS stanza and fixed typo.
2007-02-212007-02-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* Makefile.am: Use MKDIR_P instead of mkdir_p.
2007-02-152007-02-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* Makefile.maint: Use VERSION as master source for version.m4's.
* VERSION: Sync with version in aclocal/version.m4.
2007-01-282007-01-28 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* Makefile.maint: Sync nomenclature with that being used in cpukit/score/include/rtems/system.h (major->minor, minor->revision).
2007-01-272007-01-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* Makefile.maint: Remove references to cpukit/score/include/rtems/system.h.
* Makefile.maint: Add CVS_RUN.
2007-01-262007-01-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* Makefile.maint: New.
