* VERSION: Updated to ada-examples-4.9.2.
* VERSION: Updated to ada-examples-4.9.1.
* VERSION: Updated to ada-examples-4.9.0.
examples-4-9-branch'.
Sprout from master 2008-09-10 14:59:03 UTC Joel Sherrill <joel.sherrill@OARcorp.com> '2008-09-10 Joel Sherrill <joel.sherrill@oarcorp.com>'
Cherrypick from OAR 1999-04-20 13:05:42 UTC Joel Sherrill <joel.sherrill@OARcorp.com> 'base GNAT/RTEMS examples':
hello_world_ada/hello.adb
* Makefile: Add new tests. Most of these eitehr demonstrate or verify a
particular functionality.
* cpuuse/Makefile, cpuuse/cpuuse.adb, exception_test2/Makefile,
exception_test2/exceptiontest2.adb, exception_test3/Makefile,
exception_test3/exceptiontest3.adb: New files.
* .cvsignore: Add new tests. Most of these eitehr demonstrate or verify
a particular functionality.
* Makefile.shared: (pc386) Make sure .exe is file to run.
* Makefile.shared: Update Makefiles.
* Makefile: Update Makefiles.
* Makefile, rtems_init.c: Add ada_from_c_task example.
* Makefile, ada_from_c.adb, app.c, config.h, example.adb,
example.ads: New files. New test to demonstrate C calling Ada.
* empty.c, task_priority.adb: Switch to 150/151. Clean up output.
* Makefile.shared: Ignore .svn also.
* Makefile.shared: Add -g. Leave temporary files for debug.
* rtems_init.c: zero out workspace and heap automatically. This
is required by the GNAT run-time.
* interrupt_pkg.adb: Force an RTEMS shutdown when we are done.
* ChangeLog: New file.
* gen-soccon.c, gsocket.h, init.c: Update.
* Makefile: Added exception_test.
* ChangeLog, Makefile, exception_test.adb: New files.
* ChangeLog, Makefile, empty.c, task_priority.adb: New files.
* Makefile.shared, rtems_init.c: More clean up and more generalization.
* gen-soccon.c, gsocket.h: Update to GCC SVN trunk.
* Makefile, Makefile.shared, rtems_init.c, irq_test/interrupt_pkg.adb,
irq_test/interrupt_pkg.ads, irq_test/irqforce.c,
irq_test/irqtest.adb, rootfs/etc/hosts: Adding new tests as
improvements are made to the RTEMS port of the GNAT run-time.
* empty/Makefile, empty/README, empty/empty.adb,
hello_via_task/.cvsignore, hello_via_task/Makefile,
hello_via_task/hello.adb, irq_test/.cvsignore, irq_test/Makefile,
irq_test/README, irq_test_c/.cvsignore, irq_test_c/Makefile,
irq_test_c/README, irq_test_c/init.c, irq_test_c/irqforce.c: New files.
* check-off.txt, check-on.txt: New files.
* pingpong.adb: Adding new tests as improvements are made to the RTEMS
* .cvsignore: New file.
* .cvsiginore: Removed.
* Makefile.shared: Change bin2c to rtems-bin2c.
* gen-soccon.c: Update copyright.
* Makefile: Fix typo in name of program.
* init.c: Eliminate warning.
* gsocket.h: Version submitted.
* stack_check.adb: Smaller array still trips the overflow quick enough.
* Makefile: Add stack_check test.
* Makefile.shared: Add EXTRA_GNATFLAGS so stack_check can specify
the flags -fstack-check.
* .cvsiginore, ChangeLog, Makefile, README, stack_check.adb: New files.
* gsocket.h: This version of gsocket.h compiles in and out of the GCC
build system.
* rootfs/etc/host.conf, rootfs/etc/hosts: New files.
* ChangeLog: New tests. Clean up. Rework so all tests use the same
shared Makefile for the hard logic of producing an executable.
* Makefile, Makefile.shared, README.Makefiles, networkconfig.h,
rtems_init.c: New files.
* ChangeLog, Makefile, README, dumpwebpage.adb: New files.
* .cvsiginore, ChangeLog, Makefile, README, delay_until.adb: New files.
* ChangeLog, Makefile, README, pingpong.adb: New files.
* README: New tests. Clean up. Rework so all tests use the same shared
* Makefile, pc386-elf2boot: New files.
* Makefile.anybsp: Removed.
* ChangeLog, Makefile, README, gen-soccon.c, gsocket.h, init.c: New files.
* Makefile.anybsp: pc86 now builds with Makefile.anybsp.
* Makefile.pc386: Removed.
* Makefile.anybsp: ep5200 renamed icecube. Trigger special case logic
on RTEMS_BSP_FAMILY not RTEMS_BSP.
* init.c: Remove print.
* hello_world_ada/Makefile.anybsp, hello_world_ada/Makefile.pc386,
hello_world_ada/init.c: Clean up.
* hello_world_ada/.cvsiginore, hello_world_ada/README: New files.
* hello_world_ada/Makefile.score603e, hello_world_ada/README.ERC32,
hello_world_ada/README.PSIM, hello_world_ada/gdb.psim: Removed.
hello_world_ada/Makefile.score603e, hello_world_ada/init.c: Clean up
GNAT_MAIN_STACKSIZE.
* hello_world_ada/Makefile.pc386, hello_world_ada/init.c: Update to gcc
4.2.0 and rtems 4.8.
* hello_world_ada/Makefile.anybsp: New file.
* hello_world_ada/Makefile.erc32, hello_world_ada/Makefile.jmr3904,
hello_world_ada/Makefile.psim: Removed.
* VERSION: Updated to ada-examples-4.7.1.
* VERSION: Updated to ada-examples-4.7.0.
* VERSION: Updated to ada-examples-4.6.0.
* VERSION: Updated to ada-examples-20030129.
