2021-07-21 | spec/build/testsuites/grpqual.ymlqual-26 | Sebastian Huber | |
2021-07-21 | cpukit/include/rtems/score/basedefs.h | Sebastian Huber | |
2021-07-21 | validation: Support RTEMS_COVERAGE | Sebastian Huber | |
2021-07-21 | bsp/leon3: Move leon3_power_down_loop() | Sebastian Huber | |
2021-07-21 | bsp/leon3: Add LEON3_L2CACHE_BASE | Sebastian Huber | |
2021-07-21 | bsp/leon3: Add LEON3_HAS_ASR_22_23_UP_COUNTER | Sebastian Huber | |
2021-07-21 | bsp/leon3: Add LEON3_IRQAMP_PROBE_TIMESTAMP | Sebastian Huber | |
2021-07-21 | bsp/leon3: LEON3_PLB_FREQUENCY_DEFINED_BY_GPTIMER | Sebastian Huber | |
2021-07-21 | bsp/leon3: Add LEON3_IRQAMP_BASE | Sebastian Huber | |
2021-07-21 | bsp/leon3: Add LEON3_GPTIMER_BASE | Sebastian Huber | |
2021-07-21 | bsp/leon3: Add LEON3_APBUART_BASE | Sebastian Huber | |
2021-07-21 | bsp/leon3: Use new L2CACHE register block API | Sebastian Huber | |
2021-07-21 | bsp/leon3: Use new GPTIMER register block API | Sebastian Huber | |
2021-07-21 | bsp/leon3: Move up-counter support | Sebastian Huber | |
Move, document, and reformat support functions from <leon.h> to <bsp/leon3.h>. | |||
2021-07-21 | bsp/leon3: Move system control register support | Sebastian Huber | |
2021-07-21 | bsp/leon3: Use new IRQ(A)MP register block API | Sebastian Huber | |
2021-07-21 | bsps: Use new APBUART register block API | Sebastian Huber | |
2021-07-21 | bsp/leon3: Move and simplify bsp_irq_fixup() | Sebastian Huber | |
2021-07-21 | bsp/leon3: Untangle interrupt controller support | Sebastian Huber | |
Separate the probing of the interrupt controller from the initialization. | |||
2021-07-21 | bsps/sparc/include/dev/grlib/io.h | Sebastian Huber | |
2021-07-21 | validation: Add SetIOReleaxHandler() | Sebastian Huber | |
2021-07-21 | score: Add _IO_Relax() | Sebastian Huber | |
2021-07-21 | validation: Test bsp_interrupt_spurious() | Sebastian Huber | |
Update #3269 | |||
2021-07-21 | bsp/leon3: Do not invalidate cache in SMP start | Sebastian Huber | |
Since the trap table is now statically initialized, there is no need to invalidate the instruction cache. | |||
2021-07-21 | tm27.h | Sebastian Huber | |
2021-07-21 | bsp/leon3: Use interrupt entry directives | Sebastian Huber | |
2021-07-21 | FIXME libtest: Increase line length | Sebastian Huber | |
2021-07-21 | grlib: Add generated headers | Sebastian Huber | |
2021-07-21 | validation: Use unprotected chain directives | Sebastian Huber | |
2021-07-21 | validation: Use self suspend instead of exit | Sebastian Huber | |
This fixes errors in RtemsModelEventsMgr_Teardown(). | |||
2021-07-21 | build: Add tr-model-events-mgr-4.c | Sebastian Huber | |
2021-07-21 | Adds revised Event Mgr test files | abutterfield-ext | |
2021-07-21 | Adds working Chain API Tests | abutterfield-ext | |
2021-07-21 | Factors out common boilerplate and passes all tests | abutterfield-ext | |
2021-07-21 | validation: Increase stack size for -O0 | Sebastian Huber | |
2021-07-21 | validation: Test rtems_task_restart() | Sebastian Huber | |
2021-07-21 | validation: Test rtems_task_exit() | Sebastian Huber | |
2021-07-21 | validation: Test rtems_task_wake_when() | Sebastian Huber | |
2021-07-21 | validation: Test rtems_task_wake_after() | Sebastian Huber | |
2021-07-21 | validation: Test clock_nanosleep() | Sebastian Huber | |
2021-07-21 | validation: Code for timer server-fire-when test | Frank Kühndel | |
Adding tc-timer-server-fire-when.c to validation-2.yml | |||
2021-07-21 | validation: Code for timer server-fire-after test | Frank Kühndel | |
Adding tc-timer-server-fire-after.c to validation-2.yml | |||
2021-07-21 | validation: Code for timer fire_when tests | Frank Kühndel | |
This additional manual crafted code is needed to compile the timer manager tests for rtems_timer_fire_when(). validation-2.yml: Add the new test file. | |||
2021-07-21 | validation: Code for timer fire-after tests | Frank Kühndel | |
Adding tc-timer-fire-after.c to validation-2.yml. | |||
2021-07-21 | validation: Code for timer cancel & rests tests | Frank Kühndel | |
This additional manual crafted code is needed to compile the timer manager tests for rtems_timer_cancel() and rtems_timer_reset(). validation-2.yml: Add the new test files. testsuites/validation/tx-timer-server.c: New functions to permit tests to read RTEMS timer internal states. | |||
2021-07-21 | validation: Add task manager tests | Sebastian Huber | |
2021-07-21 | validation: Test scheduler manager directives | Sebastian Huber | |
2021-07-21 | validation: Add SMP-only and non-SMP test suites | Sebastian Huber | |
2021-07-21 | validation: Test memory allocation directives | Sebastian Huber | |
2021-07-21 | validation: Test rtems_timer_initiate_server() | Frank Kühndel | |
