* | smptests/smp01: Do not assume CPU 0 runs Init | Sebastian Huber | 2013-05-27 | 1 | -19/+22 |
* | smptests/smp01: Fix semaphore count | Sebastian Huber | 2013-05-27 | 8 | -3/+12 |
| | | | | The locked print needs one semaphore. | ||||
* | dosfs: Add RTEMS_DOSFS_SEMAPHORES_PER_INSTANCE | Ralf Kirchner | 2013-05-24 | 1 | -0/+1 |
* | fstests: Use "tmacros.h" instead of "pmacros.h" | Ralf Kirchner | 2013-05-24 | 1 | -1/+1 |
* | sptests: add test to demonstrate bug in strict order mutex | Gedare Bloom | 2013-05-20 | 6 | -1/+257 |
* | sptests: add test for priority inversion with multiple locks | Gedare Bloom | 2013-05-20 | 6 | -1/+211 |
* | fstests/fsstatvfs: Fix end of test message | Sebastian Huber | 2013-05-16 | 1 | -1/+1 |
* | dosfs: Add statvfs() support | Andrei Mozzhuhin | 2013-05-16 | 5 | -0/+141 |
* | libtests/malloc04: Prevent compiler optimizations | Sebastian Huber | 2013-05-10 | 1 | -1/+6 |
* | score: Add CPU context validation | Sebastian Huber | 2013-05-10 | 6 | -0/+222 |
* | psxtests/psxtime: Reduce test time | Sebastian Huber | 2013-05-06 | 2 | -235/+139 |
* | libtests/malloc04: Adjust for new sbrk() support | Sebastian Huber | 2013-05-03 | 3 | -49/+84 |
* | Clear the atomic conditional compilation. | WeiY | 2013-05-01 | 8 | -32/+0 |
* | libtests/exit02: New test | Sebastian Huber | 2013-04-23 | 6 | -0/+129 |
* | libtests/exit01: New test | Sebastian Huber | 2013-04-23 | 6 | -0/+151 |
* | Use uint32_t instead of long. Use unsigned defines (Prevent overflows on ↵ | Ralf Corsépius | 2013-04-17 | 2 | -6/+6 |
| | | | | 16bit targets) | ||||
* | testsuites: Fix warnings | Sebastian Huber | 2013-04-11 | 15 | -40/+51 |
* | libtests/flashdisk01: Disable for small memory BSP | Sebastian Huber | 2013-04-08 | 2 | -0/+31 |
* | sptests/spstkalloc02: Disable for small memory BSP | Sebastian Huber | 2013-04-08 | 1 | -0/+25 |
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 12 | -12394/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | libblock: Do resource allocation in one place | Sebastian Huber | 2013-02-21 | 2 | -33/+0 |
| | | | | | | | All resource allocations take place in rtems_bdbuf_init() now. After rtems_bdbuf_init() no fatal errors can happen due to configuration errors or resource limits. This makes it easier to detect configuration errors for users. | ||||
* | fstests/fsrdwr: Add test case | Sebastian Huber | 2013-02-20 | 3 | -1/+59 |
* | fstests/fsrdwr: Fix warning | Sebastian Huber | 2013-02-20 | 1 | -1/+1 |
* | fstests: Prevent compiler optimizations | Sebastian Huber | 2013-02-15 | 1 | -1/+4 |
* | Introduce AM_CONDITIONAL ATOMIC. | Ralf Corsépius | 2013-02-14 | 7 | -14/+28 |
* | Introduce AM_CONDITIONAL ATOMIC, cpuopt RTEMS_ATOMIC. | Ralf Corsépius | 2013-02-14 | 1 | -0/+4 |
* | sptests/spfatal11: Update due to API changes | Sebastian Huber | 2013-02-12 | 2 | -5/+22 |
* | score: Add and use rtems_assert_context | Sebastian Huber | 2013-02-12 | 2 | -5/+31 |
* | tests: atomic support for RTEMS. SMP tests for atomic operations. | WeiY | 2013-02-07 | 42 | -0/+1991 |
* | tests: atomic support for RTEMS. Uniprocessor tests for atomic ops. | WeiY | 2013-02-07 | 42 | -0/+2563 |
* | score: atomic support for RTEMS automake and autoconf changes | WeiY | 2013-02-07 | 4 | -1/+24 |
* | fstests/fsrdwr: Free allocated memory | Sebastian Huber | 2013-01-30 | 1 | -0/+4 |
* | fstests: Check resources used by FAT file system | Sebastian Huber | 2013-01-30 | 1 | -0/+6 |
* | fstests: Use global environment and clean up | Sebastian Huber | 2013-01-30 | 1 | -3/+14 |
| | | | | This releases all resources acquired by the chroot(). | ||||
* | fstests: Initialize swapout task | Sebastian Huber | 2013-01-30 | 1 | -0/+19 |
* | fstests: Perform a quick format | Sebastian Huber | 2013-01-30 | 1 | -1/+1 |
* | fstests: Use designated initializers | Sebastian Huber | 2013-01-30 | 1 | -10/+10 |
* | ftpfs: Fix SIZE command handling | Sebastian Huber | 2013-01-28 | 2 | -4/+26 |
| | | | | | | | It is invalid to issue a SIZE command once a data transfer is in progress. For reads we issue the SIZE command before the RETR command and get a snapshot of the file size. For writes the file size is initialized to zero and incremented for each write chunk. | ||||
* | testsuites: Fix prototypes | Sebastian Huber | 2013-01-27 | 6 | -16/+22 |
* | testsuites: Use rtems_fatal_source_description() | Sebastian Huber | 2013-01-27 | 4 | -27/+6 |
* | fstests: Generating .scn (Screen Shots) #4 | Alex Ivanov | 2013-01-15 | 6 | -0/+192 |
* | psxtmtests: Generating .scn (Screen Shots) #8 | Alex Ivanov | 2013-01-15 | 7 | -0/+30 |
* | Create POSIX Timing Test psxtmthread02 | Christopher Kerl | 2013-01-14 | 5 | -0/+120 |
| | | | | | Minor modifications were made to the student version to clearify methods and to clean up test output. | ||||
* | Generating .scn (Screen Shots) #7 | Alex Ivanov | 2013-01-14 | 6 | -0/+32 |
* | Create POSIX Timing Test psxtmcond09 | Christopher Kerl | 2013-01-11 | 9 | -0/+290 |
| | | | | | | Modifications were made to this submission allow the same init.c file to be ran by three tests that were very similar using posix pthread_cond_timedwait and pthread_cond_wait. | ||||
* | Create POSIX Timing Test psxtmcond03 | Christopher Kerl | 2013-01-11 | 5 | -0/+144 |
* | Added more condition variable timing tests. | Jennifer Averett | 2013-01-11 | 1 | -2/+4 |
* | Create POSIX Timing Test psxtmcond05 | Christopher Kerl | 2013-01-09 | 5 | -0/+111 |
* | Create POSIX Timing Test psxtmcond02 | Christopher Kerl | 2013-01-09 | 5 | -0/+113 |
* | GCI: Create POSIX Timing Test psxtmcond01 | Christopher Kerl | 2013-01-09 | 5 | -0/+130 |
