The SPARC ABI is a bit special with respect to the floating point context.
The complete floating point context is volatile. Thus, from an ABI point
of view nothing needs to be saved and restored during a context switch.
Instead the floating point context must be saved and restored during
interrupt processing. Historically, the deferred floating point switch was
used for SPARC and the complete floating point context is saved and
restored during a context switch to the new floating point unit owner.
This is a bit dangerous since post-switch actions (e.g. signal handlers)
and context switch extensions may silently corrupt the floating point
context.
The floating point unit is disabled for interrupt handlers. Thus, in case
an interrupt handler uses the floating point unit then this will result in a
trap (INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT).
In uniprocessor configurations, a lazy floating point context switch is
used. In case an active floating point thread is interrupted (PSR[EF] == 1)
and a thread dispatch is carried out, then this thread is registered as the
floating point owner. When a floating point owner is present during a
context switch, the floating point unit is disabled for the heir thread
(PSR[EF] == 0). The floating point disabled trap checks that the use of the
floating point unit is allowed and saves/restores the floating point context
on demand.
Update #3077.
Add new fatal error INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT.
Update #3077.
Update #3076.
Update #3076.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
Update #3076.
Update #3070.
Update #3069.
Update #3056.
Close #3036.
Close #3032.
The original CPU_COPY() support of Newlib <sys/cpuset.h> had the
parameters in the wrong order. This is fixed in Newlib since
2017-05-22.
Update #3023.
Update #2833.
Do not use the processor count to determine if SMP is enabled. Instead
use a dedicated configuration option. Enable SMP by default in SMP
configurations.
Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
otherwise.
Update #3001.
There is no need to run the task with interrupts disabled.
Update #3001.
Enable the SMP configuration by default in case SMP is enabled. Add
configuration option CONFIGURE_DISABLE_SMP_CONFIGURATION to disable it
explicitly.
otherwise.
Update #3001.
On some systems, the instruction cache invalidation is not allowed by
the MMU.
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
Update #2692.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Close #2895.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Instead of using the target time and console driver, both tests now use
assertions and rtems_rate_monotonic_get_status() to verify the count of
postponed jobs. The setting of spedfsched04 is slightly changed.
Close #2795.
Prepare a precondition to prevent the potential integer overflow.
Remove one redundant parameter in _Rate_monotonic_Renew_deadline().
sptests/sprmsched02: Create
A test case for checking the overflow condition of postponed_jobs
in rtems_rate_monotonic_period_status.
Update #2885.
Use forward and reverse order for initial and dynamic extensions. This
is the behaviour documented in the C Users Guide. Change thread
terminate order to backward to be in line with the thread delete order.
Change fatal error order to forward to ensure that initial extensions
are called first due the peculiar execution context of fatal error
extensions, see _Terminate() documentation.
Update #2692.
Add a variable named "count" in rtems_rate_monotonic_period_status
structure. Revise rtems_rate_monotonic_get_status() for the postponed
job count.
sptests/sp69: Add in the verification of the postponed job count for
rtems_rate_monotonic_get_status().
Update #2795.
Merge into one file and fix obvious problems (e.g. out of bounds array
access).
Update #2795.
access).
Update #2795.
closes #2795
Update #2795.
Update #2795.
Add POSIX shared memory manager (Shm). Includes a hook-based
approach for the backing memory storage that defaults to the
Workspace, and a test is provided using the heap. A test is
also provided for the basic use of mmap'ing a shared memory
object. This test currently fails at the mmap stage due to
no support for mmap.
Update #2825.
Update #2825.
Update #2825.
Update #2825.
Update #2825.
Update #2825.
Update #2825.
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
Data obtained on QorIQ T4240 running with 1500MHz.
