Use -B for the linker since some architectures use extra start files defined by
the GCC specification and provided by the BSP, for example powerpc. Start
files are not found by -L.
In the long run, the GCC defined start files should be provided by GCC. This
is a GCC 11 topic.
Update #3818
This is the first test case generated from a specification item in the
rtems-central repository.
Update #3959.
Add a general purpose test suite for validation tests.
This is the first test suite generated from a specification item in the
Update #3959.
In contrast to rtems_task_create() this function constructs a task with
a user-provided task storage area. The new directive uses a
configuration structure instead of individual parameters.
Add RTEMS_TASK_STORAGE_SIZE() to calculate the recommended size of a
task storage area based on the task attributes and the size dedicated to
the task stack and thread-local storage. This macro may allow future
extensions without breaking the API.
Add application configuration option
CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE to adjust RTEMS
Workspace size estimate.
Update #3959.
Add this application configuration option. This configuration option can be
used to reserve space for the dynamic linking of modules with thread-local
storage objects.
Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a
thread-local storage size.
Update #4074.
Update #3818.
Make the objcopy an bld.objects() task generator.
Close #4079.
Update #3818.
Update #3818.
Update #3818.
Update #3818.
Close #4034.
This patch is for the new build system.
Update #3818.
