The Coverity issue was an ignored return value from a read()
in a loop which should have been a seek() since the data
read was ignored.
The file itself needed reformatting to conform to RTEMS style.
Closes #2139
rtems_dhcp_failsafe() can be configured at compile time with
various options. This change makes it possible to instead configure
it at runtime.
This will make it marginally larger. I haven't measured the difference
but I'll guess it's in the lower hundreds of bytes. The change could be
modified to leave it either compile time or run time configurable,
I prefer the simplicity of a single method.
closes #1905
Close #1759.
The previous timeout handling was flawed. In case a waiting thread
helped out the owner could use the scheduler node indefinitely long.
Update the resource tree in _MRSP_Timeout() to avoid this issue.
Bug reported by Luca Bonato.
Use a best-effort approach.
The use of __DATE__ prevents reproducible builds.
The __FILE__ prevents reproducible builds.
The dummy.c was a de-facto default configuration. Rename it to
default-configuration.c. Use unlimited objects and the stack checker.
This makes it easier for new RTEMS users which will likely use this file
if they just work with the usual main() function as the application
entry point. Provide proper arguments for main() using the BSP command
line. Add spare user extensions and drivers.
Do not initialize the network by default. Delete bspinit.c.
ignored by doxygen
* Coding style cleanups.
* Use OS reserved trap 0x89 for IRQ Disable
* Use OS reserved trap 0x8A for IRQ Enable
* Add to SPARC CPU supplement documentation
This will result in faster Disable/Enable code since the
system trap handler does not need to decode which function
the user wants. Besides the IRQ disable/enabled can now
be inline which avoids the caller to take into account that
o0-o7+g1-g4 registers are destroyed by trap handler.
It was also possible to reduce the interrupt trap handler by
five instructions due to this.
Similar to the task priority option, the new CPU affinity
option is first controlled by the RPCI specific rpciodCpuset
option. If that is not set, it uses the global network task config.
If that is also not set, it falls back to not setting the affinity
at all, using all CPUs.
This patch adds a default network tasks CPU affinity configuration
option. The network drivers have the option to create their own
daemon tasks with a custom CPU affinity set, or rely on the
default set.
The hack was a debug aid and is not needed.
Close #2203.
Add lifetime bytes allocated and freed since they were present in the
malloc statistics. Add number of failed allocations.
Print out heap statistics via the MALLOC and WKSPACE shell commands.
Use the heap handler statistics instead. Add heap walk option to MALLOC
shell command.
close #1367
Bug report by Oleg Kravtsov:
In rtems_bdbuf_swapout_processing() function there is the following
lines:
if (bdbuf_cache.sync_active && !transfered_buffers)
rtems_id sync_requester;
rtems_bdbuf_lock_cache ();
Here access to bdbuf_cache.sync_active is not protected with anything.
Imagine the following test case:
1. Task1 releases buffer(s) with bdbuf_release_modified() calls;
2. After a while swapout task starts and flushes all buffers;
3. In the end of that swapout flush we are before that part of code, and
assume there is task switching (just before "if (bdbuf_cache.sync_active
&& !transfered_buffers)");
4. Some other task (with higher priority) does bdbuf_release_modified
and rtems_bdbuf_syncdev().
This task successfully gets both locks sync and pool (in
rtems_bdbuf_syncdev() function), sets sync_active to true and starts
waiting for RTEMS_BDBUF_TRANSFER_SYNC event with only sync lock got.
5. Task switching happens again and we are again before "if
(bdbuf_cache.sync_active && !transfered_buffers)".
As the result we check sync_active and we come inside that "if"
statement.
6. The result is that we send RTEMS_BDBUF_TRANSFER_SYNC event! Though
ALL modified messages of that task are not flushed yet!
close #1485
close #2030
Ensure that scheduler nodes in the SCHEDULER_HELP_ACTIVE_OWNER or
SCHEDULER_HELP_ACTIVE_RIVAL helping state are always
SCHEDULER_SMP_NODE_READY or SCHEDULER_SMP_NODE_SCHEDULED to ensure the
MrsP protocol properties.
Add rtems_cache_coherent_free() and rtems_cache_coherent_add_area().
CodeSonar flagged this as a case where the user could inject a format
string and cause issues. Since we were not printing anything but a
string, just switching to puts() rather than fprintf(stdout,...) was
sufficient to make this code safer.
CodeSonar flagged this as a possible NULL deference. This should never
occur but adding the _Assert() ensures we are guarding against that.
CodeSonar flagged this as a potential NULL deference. That should never
occur but adding the _Assert() ensures we are checking that.
CodeSonar flagged this as an empty if body. Upon analysis, it turned
out to be an error that we think should never occur but if it did,
there is nothing we could do about it. It would likely just indicate
the thread was deleted before we got here. Adding the _Assert() at least
will flag this if it ever occurs during a debug build and we can discuss
what happened.
snprintf() places a limit on the length of the output from sprintf()
and avoids similar buffer overrun issues.
CodeSonar flagged this as a possible dereference of a NULL pointer.
This should never occur so adding _Assert().
CodeSonar flagged the increment of this pointer as unneeded. The pointer
is not used past this point.
CodeSonar flagged this as a case where the return value from fat_sync()
was not used. Now it is used to return pass/fail to the caller.
These were flagged by CodeSonar. The assignments on variable declaration
are overridden a few lines below and the other line later with name_size
is where name_size was not used after this assignment.
This was flagged as an empty for statement by CodeSonar but is actually
unreachable code that should be removed.
