Release the buffers also if this is not the last reference to the file
object since otherwise we may hold modified data indefinitely.
Only continue the session if the root and current directory change was
successful, otherwise the FTP server may access restricted file system
areas.
It is invalid to issue a SIZE command once a data transfer is
in progress. For reads we issue the SIZE command before the RETR
command and get a snapshot of the file size. For writes the file size
is initialized to zero and incremented for each write chunk.
These two header files were installed from libnetworking even
when networking was disabled. This patch moves them to a
non-networking location and updates uio.h to match the FreeBSD 8.x
source being used for the USB stack and TCP/IP stack upgrade.
- cpukit/include/memory.h
Move from cpukit/libnetworking/memory.h. No changes
- cpukit/include/sys/uio.h
Move from cpukit/libnetworking/sys/uio.h. Replace with FreeBSD 8.x version.
- cpukit/include/sys/_iovec.h
New. FreeBSD 8.x file supporting <sys/uio.h>.
- cpukit/Makefile.am
Reflect movement of <memory.h> and <sys/uio.h>.
- cpukit/preinstall.am
Regenerate
- cpukit/libnetworking/nfs/bootp_subr.c
Eliminate use of uio_procp field no longer in FreeBSD structure. This
field was set and never read so eliminating the set has no impact.
This fix is critical. The previous implementation leads to system
corruption.
This is the result of a sed script which converts all uses
of @{ into a consistent form.
Change rtems-rfs to rtems_rfs
The output of the modules.html is much improved. Most
filesystem and POSIX API related groups are properly nested.
Some formatting issues were addressed as were multiple
inconsistencies.
http://www.google-melange.com/gci/task/view/google/gci2012/8110207
The _MPCI_table may be NULL in case multiprocessing is disabled in the
application configuration.
Avoid assert() and use proper cleanup if nfsInit() fails to allocate a
resource.
http://www.google-melange.com/gci/task/view/google/gci2012/8137204
http://www.google-melange.com/gci/task/view/google/gci2012/8120204
Patch committed with fixes for whitespace issues.
Check for a satisfied event condition only once.
Remove superfluous test for _ISR_Is_in_progress().
It is impossible to reach the simplified expression if we are in the
THREAD_BLOCKING_OPERATION_TIMEOUT state since in this case Wait.count
(event condition) would be set to zero and thus the seized event set
would be empty.
Commit 4b45c1393ce4ee3e1c2762ef3145d2bd6b5b38da marked a test in
_Event_Timeout() as debug only. This test is required also in non-debug
configurations since otherwise state corruption can happen. A revised
test sptests/spintrcritical10 checks the relevant sequences.
Rename arm_status_irq_enable() to _ARMV4_Status_irq_enable() and
arm_status_restore() to _ARMV4_Status_restore().
Add and use _ARMV4_Exception_undef_default(),
_ARMV4_Exception_swi_default(), _ARMV4_Exception_data_abort_default(),
_ARMV4_Exception_pref_abort_default(),
_ARMV4_Exception_reserved_default(), _ARMV4_Exception_irq_default(), and
_ARMV4_Exception_fiq_default().
Provide proper CPU_Exception_frame definition for ARMv4 and use it.
Remove arm_cpu_context.
Rename arm_exc_abort_handler to ARMV4_Exception_abort_handler,
arm_exc_data_abort() to _ARMV4_Exception_data_abort(),
arm_exc_data_abort_set_handler() to
_ARMV4_Exception_data_abort_set_handler(),
arm_exc_prefetch_abort() to _ARMV4_Exception_prefetch_abort(), and
arm_exc_prefetch_abort_set_handler() to
_ARMV4_Exception_prefetch_abort_set_handler(),
Rename arm_exc_interrupt() to _ARMV4_Exception_interrupt().
