o A new data structure rtems_filesystem_global_location_t was
introduced to be used for
o the mount point location in the mount table entry,
o the file system root location in the mount table entry,
o the root directory location in the user environment, and
o the current directory location in the user environment.
During the path evaluation global start locations are obtained to
ensure that the current file system instance will be not unmounted in
the meantime.
o The user environment uses now reference counting and is protected
from concurrent access.
o The path evaluation process was completely rewritten and simplified.
The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation
method. Recursive calls in the path evaluation have been replaced
with iteration to avoid stack overflows. Only the evaluation of
symbolic links is recursive. No dynamic memory allocations and
intermediate buffers are used in the high level path evaluation. No
global locks are held during the file system instance specific path
evaluation process.
o Recursive symbolic link evaluation is now limited by
RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value
via sysconf().
o The device file system (devFS) uses now no global variables and
allocation from the workspace. Node names are allocated from the
heap.
o The upper layer lseek() performs now some parameter checks.
o The upper layer ftruncate() performs now some parameter checks.
o unmask() is now restricted to the RWX flags and protected from
concurrent access.
o The fchmod_h and rmnod_h file system node handlers are now a file
system operation.
o The unlink_h operation has been removed. All nodes are now destroyed
with the rmnod_h operation.
o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system
operations.
o The path evaluation and file system operations are now protected by
per file system instance lock and unlock operations.
o Fix and test file descriptor duplicate in fcntl().
o New test fstests/fsnofs01.
PR 1968/filesystem
* libfs/src/rfs/rtems-rfs-file.c: Fix to the seek bug where a seek
to 0 after reading the end of the file did not point to the
correct block.
* libfs/src/rfs/rtems-rfs-rtems.h,
libfs/src/rfs/rtems-rfs-trace.c: Fix the trace flags. Used to fix
the bug.
PR 1763/shell
* libmisc/shell/hexdump-conv.c: Remove debug hacks.
PR 1757/filesystem
* libfs/src/rfs/rtems-rfs-block-pos.h,
libfs/src/rfs/rtems-rfs-block.h, libfs/src/rfs/rtems-rfs-file.c,
libfs/src/rfs/rtems-rfs-rtems-file.c: Set the file size in
iop-size when a file is open. Fix lseek to end of file then write
for sizes less than half the file system block size.
* libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-rtems.h:
Fix the fstat and fchmod calls due to the change in the iop struct
where pathinfo went away. The node_access field in pathinfo was
overloaded.
* libfs/src/defaults/default_evaluate_link.c: Remove assignment.
* libfs/src/rfs/rtems-rfs-file.c: Check then load the inode is not
present on the close.
* libfs/src/rfs/rtems-rfs-format.c: Initialise the buffer chain.
* libfs/src/rfs/rtems-rfs-file.c: Various 64bit fixes.
libfs/src/nfsclient/src/cexphelp.c,
libfs/src/nfsclient/src/dirutils.c,
libfs/src/nfsclient/src/nfs.modini.c,
libfs/src/nfsclient/src/nfsTest.c,
libfs/src/nfsclient/src/rpcio.c,
libfs/src/nfsclient/src/rpcio.modini.c,
libfs/src/nfsclient/src/sock_mbuf.c,
libfs/src/nfsclient/src/xdr_mbuf.c,
libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-block.c,
libfs/src/rfs/rtems-rfs-buffer-bdbuf.c,
libfs/src/rfs/rtems-rfs-buffer-devio.c,
libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-dir-hash.c, libfs/src/rfs/rtems-rfs-dir.c,
libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-format.c,
libfs/src/rfs/rtems-rfs-group.c, libfs/src/rfs/rtems-rfs-inode.c,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-mutex.c,
libfs/src/rfs/rtems-rfs-rtems-file.c,
libfs/src/rfs/rtems-rfs-rtems-utils.c,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-shell.c,
libfs/src/rfs/rtems-rfs-trace.c: Add HAVE_CONFIG_H support to let
files receive configure defines.
* libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-file.c,
libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-shell.c: Fix printf format warning. Primarily
for size_t.
* libfs/src/rfs/rtems-rfs-block.c: Reset a buffer handle after
moving down an indirection level.
* libfs/src/rfs/rtems-rfs-dir.c: Move directory entry validation
into a macro and use the macro. Fix the range check on the ino so
all inodes can be used.
* libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file-system.h:: Add a version number to
the superblock. Use RTEMS_RFS_INODE_SIZE.
* libfs/src/rfs/rtems-rfs-file.c: Fix the size offset on partial
block lengths. Set the size in the file handle on a truncate to
0.
* libfs/src/rfs/rtems-rfs-format.c: Add a version number to
the superblock. Use RTEMS_RFS_INODE_SIZE. A better set of defaults
for small disks.
* libfs/src/rfs/rtems-rfs-inode.c: Use RTEMS_RFS_INODE_SIZE. Free
the allocated inode if it cannot be opened.
* libfs/src/rfs/rtems-rfs-inode.h: Add RTEMS_RFS_INODE_SIZE.
* libfs/src/rfs/rtems-rfs-rtems-file.c: Move some of the iop
acceses inside the fs lock.
* libfs/src/rfs/rtems-rfs-shell.c: Use RTEMS_RFS_INODE_SIZE.
* libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-bitmaps.h,
libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h,
libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h,
libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h,
libfs/src/rfs/rtems-rfs-dir-hash.h,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h,
libfs/src/rfs/rtems-rfs-file-system-fwd.h,
libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h,
libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h,
libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h,
libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h,
libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h:
New.
* Makefile.am, preinstall.am, libfs/Makefile.am,
wrapup/Makefile.am: Updated with the RFS support.
* libfs/README: Updated after 10 years.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk-driver.c: Updated to the new error reporting
in libblock.
* libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing
the size in long mode.
* libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bootp.c,
libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP
to the forever behaviour of 4.9 with the ability to call BOOTP and
control the process if required.
