path: root/cpukit/include/rtems/rtems/signalmp.h (follow)
* rtems: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-2/+2
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* rtems: Canonicalize implementation Doxygen groupsSebastian Huber2020-12-021-6/+8
| | | | | | | | | Rename Classic API top-level group from Classic to RTEMSImplClassic. Use RTEMSImplClassic as a prefix for the subgroups. Change the group names to be in line with the API group names. Use common phrases for the group brief descriptions. Update #3706.
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+98
