close #2211
Fixes bug introduced with dff1803cfbec3775fff1b9c34cc707c05494dc3b.
The dummy.c was a de-facto default configuration. Rename it to
default-configuration.c. Use unlimited objects and the stack checker.
This makes it easier for new RTEMS users which will likely use this file
if they just work with the usual main() function as the application
entry point. Provide proper arguments for main() using the BSP command
line. Add spare user extensions and drivers.
Do not initialize the network by default. Delete bspinit.c.
On recent u-boots, the watchdog is turned on / left enabled. The
Beaglebone Black rev. C ships with such a u-boot internally so any
application booting from it must disable the watchdog.
Therefore this change is needed to boot an RTEMS app out-of-the-box
on a BBB Rev C - otherwise the user button must be held during boot
(to bypass the stock uboot) or the internal uboot must be updated. To
allow for a better out-of-the-box experience, we just turn off the
watchdog.
structs, break >80 chars lines, removed newlines at EOFs
fb_vesa_rm.c: removed inline from functions declared in fb_vesa.h
removed unnecessary printks in the end of patch
edid.h, vbe3.h: switched from custom *PACKED_ATTRIBUTE at the structs to the
RTEMS_COMPILER_PACKED_ATTRIBUTE for easier maintainability
of doxygen
* Coding style cleanups.
* Use OS reserved trap 0x89 for IRQ Disable
* Use OS reserved trap 0x8A for IRQ Enable
* Add to SPARC CPU supplement documentation
This will result in faster Disable/Enable code since the
system trap handler does not need to decode which function
the user wants. Besides the IRQ disable/enabled can now
be inline which avoids the caller to take into account that
o0-o7+g1-g4 registers are destroyed by trap handler.
It was also possible to reduce the interrupt trap handler by
five instructions due to this.
If USE_VBE_RM is 0, vesa_realmode_bootup_init() is not available so the
test should be #if instead of #ifdef.
Previously, bankValidate() could be called (e.g., BSP_flashWrite() -> regionCheckAndErase() -> argcheck() -> bankValidate()) without the probe having happened. When it then invoked BSP_flashCheckId(), unmapped memory could be read, possibly causing a fatal exception.
Condition needs to be inverted, as a 1 in the mask register means
that the interrupt is enabled. Solves ticket #1959 in trac.
that the interrupt is enabled. Solves ticket #1958 in trac.
Save five instructions on underflow handling.
By using an optimized trap entry we can move instructions from
the window underflow function into the trap entry vector. By
setting WIM=0 and using RESTORE it is possible to move the
new WIM register content from the trapped window into the
to-be-restored register window. It is then possible to avoid
the WIM write delay.
By using a optimized trap entry we can move instructions from
the window overflow function into the trap entry vector. By
using the saved locals instead of g1 we don't need to save
that register temporarily. Also spead out non store instructions
inbetween stores to use the write buffer better.
I see no need for waiting the 3 instruction delay for wim to be
written in this case, since the STD after does not depend on WIM
Move the vector table copy out of the Init5235 source to avoid
stipping the GCC bug.
Fixes #2204.
close #2062
This section can be use to provide a cache coherent memory area via
rtems_cache_coherent_add_area().
This was flagged by CodeSonar.
This was flagged by CodeSonar. It should be impossible to get an
incorrect baud number back but ensure this in debug mode. The _Assert()
keeps their scanner from evaluating for divide by 0 past this point.
Make sure also the size is cache aligned since otherwise we may have
some overlap with the next allocation block. A cache invalidate on this
area would be fatal.
This option is necessary to use the latest GCC 4.8, 4.9 and 5.0
versions.
close #2113
close 1405
Include <sys/param.h> if necessary to get the MIN()/MAX() macros.
Display Identification Data
Optimize locking.
Simplify initialization. Replace some assert() with fatal errors.
Rename BSP_ARM_L2CC_BASE to BSP_ARM_L2C_310_BASE.
