Fix infinite loop in rtems_invalidate_multiple_instruction_lines().
Implement this function.
Close #3080.
Update #3071.
Rename NGMP to GR740 and add configs for UT699, UT700, and GR712RC
The UT699 requires -mcpu=leon as it does not support the CAS instruction
provided by -mcpu=leon3. It also requires -mfix-ut699 for errata fixes.
UT700 and GR712RC requires the -mfix-ut700 and -mfix-gr712rc flags that
have been recently added to GCC's master and 7-branch.
Remove -msoft-float from the leon3 config to make the more common case
of using the FPU the default.
Update #3057.
This patch adds NOP instructions to prevent instruction sequences
that are sensitive to the LEON3FT B2BST errata. See GRLIB-TN-0009:
"LEON3FT Stale Cache Entry After Store with Data Tag Parity Error"
for more information.
The sequences are only modified if __FIX_LEON3FT_B2BST is defined.
The patch works in conjunction with the -mfix-ut700, -mfix-gr712rc,
and -mfix-ut699 GCC flags that prevents the sensitive sequences from
being generated.
Update #3057.
Update #3071.
Close #3071.
Update #3071.
Update #3071.
This mechanism can be used to safely move the interrupt server from one
scheduler instance to another for example.
Update #3071.
This allows load balancing of interrupt processing in SMP
configurations.
Update #3071.
Update #3059.
Update #3059.
Implement the Processor_mask via <sys/bitset.h>. Provide
_Processor_mask_To_uint32_t() to enable its use in device specific
routines, e.g. interrupt affinity register in an interrupt controller.
Update #3059.
Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
to not return a status code. Add bsp_interrupt_assert() and use it to
validate the vector number in the vector enable/disable implementations.
Close #3051.
Update ticket #2891 and my GSOC project
add c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
modify c/src/lib/libbsp/arm/beagle/include/i2c.h
modify c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
modify c/src/lib/libcpu/arm/shared/include/am335x.h
modify c/src/lib/libbsp/arm/beagle/Makefile.am
Now can read the EEPROM by i2c, the test application link is: https://github.com/hahchenchen/GSOC-test-application
delete c/src/lib/libbsp/arm/beagle/misc/i2c.c
According to manual, the used operations (Clean Line by PA, Clean and
Invalidate Line by PA, Cache Sync) are atomic and do not require
locking.
Update #3007.
Update #2833.
Update #2833.
Update #2833.
Update #2468.
Fix format warnings.
There is no need to save the thread pointer in _CPU_Context_switch()
since it is a thread invariant. It is initialized once in
_CPU_Context_Initialize().
Enable/disable vector routines now check for a valid vector. Without
these guards, the enable/disable vector routines will not work with the
interrupt server.
Update #2833.
Remove obsolete support for OFILL, OFDEL, NLDLY, CRDLY, BSDLY, VTDLY,
and FFDLY which is not present on FreeBSD and not implemented in Linux.
Update #2833.
Update #2833.
Update #2289.
There are mismatched sections in the bootloader input:
ld: Warning: ticker.exe uses hard float, ticker.ralf uses soft float
ld: ticker.exe: compiled normally and linked with modules compiled with -mrelocatable
ld: failed to merge target specific data of file ticker.exe
Suppress this error explicitly.
Set the proper output format in the linker script for the bootloader.
Otherwise the generic linker is used since Binutils 2.28 which does not
understand the PowerPC-specific relocations.
Closes #3015.
Update #2493.
Update #2676.
Update #2477.
Closes #3025.
The SYM define concatenates the input with the compiler set
__USER_LABEL_PREFIX__ define. This define appears to be '_' in GCC but
empty in Clang. Therefore when compiling with Clang/LLVM 'SYM(start)'
and 'start' defines the same symbol, and the compiler complains that the
symbol is defined twice.
- All references of %0 changed to %g0
- 'call label,0' changed to 'call label'. According to the sparc
specification call does not take any registers
- '.seg "text"' changed to '.section ".text"'
- the synonym stub is replaced with stb
- the synonym stuh is replaced with sth
The following functions now reports to the user that an overrun has
occured by returning errno EIO:
* grtc_read, on overrun and no more data in the DMA buffer
* ioctl(GRTC_IOC_RECV), on overrun and no more frames in the DMA buffer
* ioctl(GRTC_IOC_ISSTARTED), EIO is returned on overrun
