* | bsps/powerpc: Add and use ppc_cpu_is_specific_e200 | Sebastian Huber | 2013-02-06 | 2 | -2/+10 |
* | bsps/powerpc: Fix e200 check | Sebastian Huber | 2013-02-06 | 1 | -4/+2 |
* | bsp/mpc55xx: Add mpc55xx_mmu_apply_config() | Sebastian Huber | 2013-02-06 | 1 | -2/+12 |
* | bsp/mpc55xx: Add BSP_DATA_CACHE_USE_WRITE_THROUGH | Sebastian Huber | 2013-01-28 | 3 | -2/+13 |
* | bsps/powerpc: Add option for write-through cache | Sebastian Huber | 2013-01-28 | 1 | -1/+2 |
* | bsp/mpc55xx: Fix MMU configuration for RSM6 | Sebastian Huber | 2013-01-28 | 1 | -4/+4 |
* | Fixed virtex4,5 BSP compile time warnings | Ric Claus | 2013-01-26 | 6 | -7/+11 |
* | bsp/gen83xx: Disable caches in bsp_restart() | Sebastian Huber | 2013-01-18 | 1 | -1/+23 |
* | bsp/virtex5: Fix define location | Sebastian Huber | 2013-01-14 | 1 | -3/+2 |
* | bsp/lpc32xx: Bypass the IrDA modem for UART6 | Sebastian Huber | 2013-01-11 | 1 | -3/+6 |
* | bsps/arm: Fix LPC Ethernet driver initialization | Sebastian Huber | 2013-01-09 | 1 | -0/+3 |
* | bsp/gen83xx: Register I2C SEMTECH SC620 driver | Sebastian Huber | 2013-01-09 | 1 | -0/+12 |
* | libchip: Add I2C SEMTECH SC620 octal LED driver | Sebastian Huber | 2013-01-09 | 4 | -0/+141 |
* | bsps/powerpc: Add probe handler to I2C driver | Sebastian Huber | 2013-01-09 | 3 | -54/+57 |
* | bsps/powerpc: Fix compiler warnings | Sebastian Huber | 2013-01-09 | 1 | -4/+1 |
* | bsp/gen83xx: Invalidate caches only if disabled | Sebastian Huber | 2013-01-09 | 1 | -3/+10 |
* | bsp/gen83xx: System reset after fatal conditions | Sebastian Huber | 2013-01-09 | 1 | -1/+1 |
* | bsp/gen83xx: Add bsp_restart() | Sebastian Huber | 2013-01-09 | 3 | -0/+27 |
* | bsp/gen83xx: Delete obsolete region | Sebastian Huber | 2013-01-09 | 1 | -1/+0 |
* | leon3: disable unused ISR handler | Joel Sherrill | 2013-01-08 | 1 | -0/+2 |
* | leon3/shmsupp: Fix warnings & comment clean up | Joel Sherrill | 2013-01-08 | 3 | -65/+36 |
* | leon3: Open Ethernet Fixed Warning | Joel Sherrill | 2013-01-08 | 1 | -1/+1 |
* | no_bsp: Fix typo and format | Joel Sherrill | 2013-01-08 | 1 | -10/+10 |
* | m68k/mvme167: Compiles again | Joel Sherrill | 2013-01-08 | 3 | -48/+36 |
| | | | | | | Was including non-existent .h file. Fixed some warnings. Reformatted file header comment blocks. | ||||
* | arm/smdk2410: Update to include bspidle.c | Joel Sherrill | 2013-01-08 | 1 | -1/+1 |
| | | | | | This BSP shares code with the gp32 and needed to include the new bspidle.c file. | ||||
* | arm/gp32: Correct compilation error in BSP Idle Thread | Joel Sherrill | 2013-01-08 | 4 | -24/+38 |
| | | | | | | | Split BSP Idle Thread into separate file to follow convention used on other BSPs. Slight reformatting of file header comment block. | ||||
* | bsp/lpc24xx: Declare conditionally | Sebastian Huber | 2013-01-07 | 1 | -0/+4 |
* | bsp/lpc32xx: System reset after fatal conditions | Sebastian Huber | 2013-01-07 | 1 | -1/+1 |
* | bsp/lpc24xx: System reset after fatal conditions | Sebastian Huber | 2013-01-07 | 1 | -1/+1 |
* | bsp/lpc24xx: Request system reset for LPC17XX | Sebastian Huber | 2013-01-07 | 1 | -4/+6 |
* | bsp/lpc24xx: Add WWDT module defines | Sebastian Huber | 2013-01-07 | 1 | -1/+21 |
* | arm: Add and use _ARMV7M_Exception_default() | Sebastian Huber | 2013-01-07 | 1 | -15/+16 |
* | arm: Rename inline functions | Sebastian Huber | 2013-01-07 | 2 | -4/+4 |
| | | | | | Rename arm_status_irq_enable() to _ARMV4_Status_irq_enable() and arm_status_restore() to _ARMV4_Status_restore(). | ||||
* | arm: Move inline functions | Sebastian Huber | 2013-01-07 | 1 | -0/+2 |
* | arm: Add and use default exception handler | Sebastian Huber | 2013-01-07 | 1 | -15/+15 |
| | | | | | | | | Add and use _ARMV4_Exception_undef_default(), _ARMV4_Exception_swi_default(), _ARMV4_Exception_data_abort_default(), _ARMV4_Exception_pref_abort_default(), _ARMV4_Exception_reserved_default(), _ARMV4_Exception_irq_default(), and _ARMV4_Exception_fiq_default(). | ||||
* | arm: Rename arm_exc_interrupt() | Sebastian Huber | 2013-01-07 | 9 | -9/+9 |
| | | | | Rename arm_exc_interrupt() to _ARMV4_Exception_interrupt(). | ||||
* | arm: Move prototypes to new file | Sebastian Huber | 2013-01-07 | 8 | -0/+15 |
| | | | | | | Move bsp_interrupt_dispatch() and arm_exc_interrupt() prototypes to new file <rtems/score/armv4.h> since they have nothing to do with the CPU port. | ||||
* | bsps: Fix rtems_interrupt_server_handler_remove() | Sebastian Huber | 2013-01-07 | 1 | -2/+2 |
* | bsp/gen83xx: Add GPR_1 to register map | Sebastian Huber | 2012-12-21 | 1 | -1/+3 |
* | bsp/gen83xx: Fix RCWLR_CEVCO defines | Sebastian Huber | 2012-12-21 | 1 | -2/+3 |
* | bsp/gen83xx: Fix CSB clock calculation for MPC8309 | Sebastian Huber | 2012-12-21 | 1 | -1/+6 |
* | bsps/arm: Move promiscuous mode setting | Sebastian Huber | 2012-12-18 | 1 | -2/+3 |
* | bsps/arm: Add PHY up/down | Sebastian Huber | 2012-12-18 | 1 | -53/+211 |
| | | | | | | | | | | | | | All PHYs will be set to power up/down state with the BMCR[BMCR_PDOWN] setting. The KSZ80X1RNL will use the energy detect power down (EDPD) mode with PLL automatically turned in the up state. It will use the slow oscillator mode in the down state. To prevent system bus lock-ups the PHY is set to the up state before Ethernet module initialization. In case of a communication failure with the PHY or weird PHY identifiers the initialization will be aborted. | ||||
* | bsps/arm: Add PHY timeout detection | Sebastian Huber | 2012-12-18 | 1 | -9/+20 |
* | bsps/arm: Add interface down support | Sebastian Huber | 2012-12-18 | 3 | -43/+105 |
* | bsps/arm: Prepare for interface down support | Sebastian Huber | 2012-12-18 | 1 | -78/+83 |
* | bsps/arm: Use assert() instead of status macros | Sebastian Huber | 2012-12-18 | 1 | -33/+9 |
* | bsps/arm: Remove superfluous attributes | Sebastian Huber | 2012-12-18 | 1 | -3/+3 |
* | bsps/arm: Avoid mbuf migration in LPC ethernet | Sebastian Huber | 2012-12-18 | 1 | -56/+30 |
| | | | | | | The receive task will only hand over a mbuf if it gets a new one immediately. This avoids mbuf migration out of the receive task in case of overload. | ||||
* | bsp/lpc32xx: Add UART_CLKMODE settings | Sebastian Huber | 2012-12-18 | 2 | -0/+4 |
