Replace the BSP_CONSOLE_MINOR BSP option for the Xilinx Zynq BSPs with the new
BSP option ZYNQ_UART_KERNEL_IO_BASE_ADDR. Move the kernel I/O support to a
shared file.
This helps to provide a shared implementation of the kernel I/O support.
Make the initialization and polled functions independent of the Termios
context. This helps to implement the kernel I/O support without a dependency
on the Termios framework.
The base addresses and IRQ numbers for UART 0 and 1 were interchanged.
Fix this and set BSP_CONSOLE_MINOR to 0 for this BSP family.
Swap the zynqmp management console to interrupt-driven operation to
avoid losing data in under-polled situations.
Include <rtems/termiostypes.h> for the Termios device driver support.
This changes the ZynqMP device tree parsing over to direct libfdt calls
to avoid inclusion of malloc() in the base BSP which currently causes
sp01 to fail due to unexpected use of TLS space.
This adds a BSP variant for the ZynqMP BSP family to support the
Innoflight CFC-400X platform. To properly support the CFC-400X, device
trees were added to the ZynqMP platform due to both the optional
management interface as well as alternate physical configuration of the
ethernet interfaces.
The existing fix for the ZynqMP UART hardware bug only caught the vast
majority of instances where it could occur. To fully fix the data
corruption, this fix must be applied after every baud rate change. This
makes the logic reset and kick apply in any locations where the baud
rate could be changed.
Constantly reinitializing the Cadence UART on every character output
causes data corruption/loss on some ZynqMP hardware. Only initialize
the UART once for early output and give it a kick on startup.
Both Qemu and actual hardware treat the second UART in memory map as the
primary UART. This adjusts the ZynqMP BSPs to match.
This adds a BSP family that runs on the Xilinx Ultrascale+ MPSOC
(ZynqMP) family of chips. It is configured to be usable on the Qemu
ZCU102 machine definition and should be almost trivially portable to
ZynqMP development boards and custom hardware. It is also configured to
be usable with libbsd.
This moves the zynq-uart driver from bsps/arm/shared to bsps/shared to
accomodate use by AArch64 BSPs.
Use RTEMS_SYSINIT_ORDER_LAST_BUT_5 instead of RTEMS_SYSINIT_ORDER_LAST
to allow applications and support functions to place system
initialization handlers behind the standard handlers.
Update #3838.
Modifications to get xilinx-zynqmp BSP working on an Ultra96 board.
Update #3682.
Source files were copied from xilinx-zynq.
Update #3682.
Relicense contributions from Chris Johns, Christian Mauderer,
embedded brains GmbH, Joel Sherrill, OAR, Pavel Pisa, Ralf Kirchner, and
Sebastian Huber.
Update #3053.
Update #3285.
