rtems_shell_debugrfs is low level debug tool for rfs. rtems_rfs_shell_* symbols are helper functions used by rtems_shell_debugrfs.
* do_coverage, rtems_config.in: Add GNU coverage support.
* generate_coverage_html, style.css: Google Code-In 2011 task to make
the tables sortable on the top level BSP page.
* do_coverage: Remove unused variable.
* do_coverage: Account for two column symbol file.
* VERSIONS-COVERAGE: Back to head.
* generate_coverage_html: Add version column.
* Explanations.txt: Minor updates.
* VERSIONS-COVERAGE: Testing 4.9.6.
* do_coverage: Default to saving tarballs.
* VERSIONS-COVERAGE: Switch to CVS head.
* generate_coverage_html: Improve help.
* VERSIONS-COVERAGE, do_coverage, run_coverage: Make improvements so it
is easier to run on released RTEMS versions.
* coverage_cron, run_coverage: Switch defaults on publishing.
* VERSIONS-COVERAGE: Add math tests as link only.
* generate_coverage_html: Fix bug again.
* VERSIONS-COVERAGE, generate_coverage_html: Add argument to disable
plots and graphs. When doing coverage for a single configuration,
this is important.
* run_coverage: Always be verbose and echo the command line.
* do_coverage, generate_coverage_html, run_coverage: Contents of
coverage data is now split into a collection of BSP specific
directories. There were over 2000 entries in the main directory of
the site before doing this. Also reworked the timeplot page to
include the legend before each graph.
* run_coverage: Parse command arguments better.
* generate_coverage_html: Add timeplot output as part of Google Code In
2010.
* generate_coverage_html: Eliminate columns with constant data and put
more detailed version of that information in the header.
* generate_coverage_html: Increase thickness of lines.
* generate_coverage_html: Add uncovered ranges.
* generate_coverage_html: Add progress tracking time/series plots.
* Explanations.txt: Remove cases which are now RTEMS_DEBUG.
PR 1659/testing
* Explanations.txt: Update.
* do_coverage: Add remove_unwanted_symbols.
* Explanations.txt: Update. Remove old ones and add a number of new
entries.
* do_coverage, rtems_items.sed: Include more info in summary.
* do_coverage: Add libdevfs which was split from libimfs.
* do_coverage: Add information on unreferenced symbols to summary.txt.
* Categories.txt, Explanations.txt: Added explinations for wrapper
functions andsome of the not implemented functions.
* Explanations.txt: Removed explanations that were resolved.
* Explanations.txt: Augment explanation.
* Categories.txt: New file.
* generate_coverage_html: Another place where sort -u should have been
after the cut.
* generate_coverage_html: sort after the cut so the cpus are unique not
the target names. This made a CPU show up twice when we had
difference RTEMS branches in the results (e.g. sparc-rtems4.10 and
sparc-rtems4.11).
* do_coverage: Until untar test is committed do not include it. It's
presence is hiding other coverage improvements.
* VERSIONS-COVERAGE, do_coverage: Now builds with 4.11.
* do_coverage: Include libuntar.
* do_coverage, rtems_items.sed: Moved the summary report to the covoar
common reports in the report class and out of the rtems specific
items in the report index.
* rtems-cvs-20090806.diff, rtems-cvs-20090819.diff,
rtems-cvs-20091201.diff: Removed.
* ChangeLog: Remove items that are general and not RTEMS specific.
* .cvsignore, 05_ascending.gif, 05_descending.gif, 05_unsorted.gif,
ConfigFile.cc, ConfigFile.h, CoverageFactory.cc, CoverageFactory.h,
CoverageMap.cc, CoverageMap.h, CoverageMapBase.cc, CoverageMapBase.h,
CoverageRanges.cc, CoverageRanges.h, CoverageReaderBase.cc,
CoverageReaderBase.h, CoverageReaderQEMU.cc, CoverageReaderQEMU.h,
CoverageReaderRTEMS.cc, CoverageReaderRTEMS.h,
CoverageReaderSkyeye.cc, CoverageReaderSkyeye.h,
CoverageReaderTSIM.cc, CoverageReaderTSIM.h, CoverageWriterBase.cc,
CoverageWriterBase.h, CoverageWriterRTEMS.cc, CoverageWriterRTEMS.h,
CoverageWriterSkyeye.cc, CoverageWriterSkyeye.h,
CoverageWriterTSIM.cc, CoverageWriterTSIM.h, DesiredSymbols.cc,
DesiredSymbols.h, Doxyfile, ERC32-Status, ExecutableInfo.cc,
ExecutableInfo.h, Explanations.cc, Explanations.h, Makefile,
ObjdumpProcessor.cc, ObjdumpProcessor.h, ReportsBase.cc,
ReportsBase.h, ReportsHtml.cc, ReportsHtml.h, ReportsText.cc,
ReportsText.h, SymbolTable.cc, SymbolTable.h, TargetBase.cc,
TargetBase.h, TargetFactory.cc, TargetFactory.h, Target_arm.cc,
Target_arm.h, Target_i386.cc, Target_i386.h, Target_lm32.cc,
Target_lm32.h, Target_m68k.cc, Target_m68k.h, Target_powerpc.cc,
Target_powerpc.h, Target_sparc.cc, Target_sparc.h, TraceConverter.cc,
TraceList.cc, TraceList.h, TraceReaderBase.cc, TraceReaderBase.h,
TraceReaderLogQEMU.cc, TraceReaderLogQEMU.h, TraceWriterBase.cc,
TraceWriterBase.h, TraceWriterQEMU.cc, TraceWriterQEMU.h,
app_common.cc, app_common.h, configFile.txt, configfile_test.cc,
coverage_converter.cc, covmerge.cc, covoar.cc, covoar.css,
covoar_flow.doc, filter.gif, qemu-dump-trace.c, qemu-log.h,
qemu-traces.h, rtemscov_header.h, skyeye_header.h, table.js: Removed.
* VERSIONS-COVERAGE, do_coverage: Created covoar directory with source
that will be moved from rtems-coverage.
* ReportsHtml.cc: Added link to size report. Added a filterable File
column to reports.
