A dirname of / is / so the path will never have a length of 0.
Close #3393
Closes #3316
Closes #3313
The option expansion is missing `--with-download'.
Close #3295
Using the RSB release version for the gcc version string means the
tools have a version string that matches the release.
Close #3074
This requires moving to markdown for HTML and so asciidoc can be removed.
Close 3289
The xz tool is not provided in Xcode command line tools and needs to
built or obtained somehow. This path can be any where so relax the
need for an absolute path.
Close #3279
Fix a minor issue in the log module.
Update #3274
The orphans check lets you see which configuration and build set
files in the RSB are not referernced. You can audit the list and
remove any configuration files not being used. Top level
build set files are included so you need to becareful not to
remove something that is valid and useful. To run:
$ ./source-builder/sb-check --check-orphans
Update #3274
Update #3274
Close #3271
The released sources use the local file name so always force it when
the RSB is released.
Closes #3064.
Newer makeinfo tools cannot build the existing texinfo in gcc so
disable building it. This will not be fixed on the gcc branches.
Updates #3027.
Upates #3033.
This change lets the LM32 target build on Windows which has temporary
install paths greated than the Win32 API max size. The buildroot path
compression is still needed as the GNU assembler does not like paths
that exceed the max Windows limit.
Closes #2992.
A release can specify a custom releaase URL path.
Closes #2952.
Close #2947.
Select MinGW compilers for Windows builds on Windows.
Use the system readline rather than GDB's which does not
handle cmd.exe correctly.
Closes #2681.
Directives in if statements end at the end of an if. The cannot
change or split across directive boundaries.
Add more trace detail to config.py.
Updates #2661.
Updates #2655.
Updates #2655.
Updates #2655.
Add support for pkgconfig checks to fail when just downloading the
source so it is actually downloaded on hosts that may have a package
installed.
Updates #2657.
Updates #2656.
Some sites block the standard python user agent. Change to Wget
as it seems to make the tested sites behave.
Limit the size of long URLs when logging to the user.
Closes #2656.
The building of 3rd party packages for an RTEMS BSP requires a valid
BSP so the standard method to download the source for releasing does
not work. This change adds support to allow this. The RTEMS BSP support
will not generate an error is no BSP or tools are provided or found.
The change addis logic operators to the %if statement so you can '||'
to 'or' and '&&' to 'and' logic expressions.
A new %log directive has been added to clean up the messages.
A new %{!define ...} has been added to aid checking within logic
expressions.
All command line --with/--without now appear as macros.
Add version.version to get just the RTEMS major and minor version.
Some pkg-config issues have been resolved.
Closes #2655.
Closes #2645.
If the package references macros yet to be defined an error is
generated. Let the macro expands happen when the package name is
actually used.
Closes #2645.
Ignore RSB generated files to keep the git dirty status clean.
Closes #2647.
Closes #2748.
Update #2526.
Provide without_release_url support in the configuration file so
the release tarball download of the kernel and tools uses the
release's top level directory and not the sources directory.
Closes #2481.
This reflects changes in the way the --with/--without options are handled.
Updates #2526.
Updates #2636.
The default without the option is to prepend the release URL to the URL
list to download from the RTEMS FTP site first if the RSB is released. This
option can force the RTEMS FTP to be tried first when not a release,
or you can supply a different URL to download from or you can request
no RTEMS URL is tried first. Eg:
--with-release-url
--with-release-url=file://opt/local/cache
--without-release-url
Move the RTEMS release URL to the default.mc file. Change the URL
to the RTEMS FTP server and do not use the https method of access.
The option's with_arg call was cleaned up to make sense.
Remove the log's raw output of an extra space.
Some download error message formating was cleaned up.
Closes #2636.
Updates #2619.
Updates #2619.
Updates #2619.
Detect a suitable Python version on Windows.
Update #2619.
Fix Windows support to allow MSYS2 Python to be used.
Updates #2619.
The query flags such as '?h=4.11' to select a branch cannot appear
in the file name on Windows. This patch removes the query part from
the file name.
Update #2616.
With a recent (Feb 2016) pytnon on MSYS2 the clear fails so delete
the variable.
Update #2613.
Windows cmd.exe does not support a single quote for options. Change to
a double quote.
Closes #2615.
Prepend 'sh' to the command so the autoreconf runs in a shell.
Is the first item in the path is a reference to MSYS2 remove it.
Closes #2613.
