* | rtems: Update to the latest rtems-tools | Chris Johns | 2020-09-07 | 1 | -2/+3 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-09-04 | 4 | -12/+12 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-08-31 | 4 | -12/+12 |
* | Move 5 build sets to 6 | Chris Johns | 2020-08-13 | 59 | -423/+115 |
| | | | | | | | | | | - Move 5/bsps/* to bsps/* - Update package build references from 5 to 6 - Remove 5 build sets. Update #4048 | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-07-29 | 4 | -12/+12 |
* | rtems-tools: Pick up fix for modern llvm. | Christian Mauderer | 2020-07-23 | 1 | -2/+2 |
* | 6/7: Remove support for epiphany target | Sebastian Huber | 2020-07-05 | 3 | -19/+0 |
| | | | | Update #3941. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-07-03 | 4 | -12/+12 |
* | moxie: Update to dtc 1.6.0 | Sebastian Huber | 2020-07-01 | 3 | -3/+3 |
| | | | | This fixes the build with a GCC 10 host compiler. | ||||
* | 6/7: Use RTEMS 6 tools | Sebastian Huber | 2020-06-30 | 4 | -3/+46 |
* | Make comment version independent | Sebastian Huber | 2020-06-30 | 1 | -1/+1 |
* | 7: Add unstable RTEMS 7 tool chain | Sebastian Huber | 2020-06-29 | 21 | -0/+114 |
* | 6: Use GCC 10 branch for RTEMS 6 tool chain | Sebastian Huber | 2020-06-29 | 3 | -2/+22 |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-06-29 | 3 | -6/+6 |
* | rtems: Update kernel, libbsd and tool the master. | Chris Johns | 2020-06-23 | 3 | -6/+6 |
| | | | | This aligns them to the branch point. | ||||
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-06-10 | 3 | -8/+8 |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-06-05 | 3 | -8/+8 |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-06-02 | 1 | -2/+2 |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-06-02 | 3 | -8/+8 |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-05-12 | 3 | -11/+8 |
* | rtems: Update the kernel | Chris Johns | 2020-05-08 | 1 | -2/+2 |
* | rtems: Update the kernel and tools packages to the latest RTEMS 5 | Chris Johns | 2020-05-07 | 2 | -4/+4 |
* | rtems-kernel: Update to the latest | Chris Johns | 2020-04-28 | 1 | -2/+2 |
* | rtems-bsb: Use linker garbage collection for BSP based builds | Chris Johns | 2020-04-28 | 1 | -1/+10 |
| | | | | Close #3944. | ||||
* | rtems-libbsd: Remove the v from the package name verision | Chris Johns | 2020-04-28 | 1 | -1/+1 |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-04-28 | 3 | -8/+8 |
* | rtems-kernel: Fix building without the rtems test option. | Chris Johns | 2020-04-28 | 1 | -2/+0 |
| | | | | Updates #3956 | ||||
* | rtems-kernel: Install tests when tests are built | Chris Johns | 2020-04-28 | 1 | -32/+61 |
| | | | | | | | | | | The tests in RTEMS are not installed so if a user requests the tests be built install them. Given the RSB cleans up building the tests and not installing does nothing. - Fix the options handling the kernel build to be consistent Updates #3956 | ||||
* | 5/rtems-libbsd: Update 5-freebsd-12 | Christian Mauderer | 2020-04-20 | 1 | -2/+2 |
* | 5/rtems-libbsd: Update 5-freebsd-12 | Christian Mauderer | 2020-04-17 | 1 | -2/+2 |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-04-17 | 3 | -8/+8 |
* | 5/rtems-libbsd: Update 5-freebsd-12 | Christian Mauderer | 2020-04-16 | 1 | -2/+2 |
* | 5/rtems: Update kernel and libbsd. | Christian Mauderer | 2020-04-15 | 2 | -4/+4 |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-04-08 | 1 | -2/+2 |
| | | | | Update #3937. | ||||
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-04-07 | 1 | -0/+3 |
* | rtems: bump rtems-5-kernel | Gedare Bloom | 2020-04-06 | 1 | -2/+2 |
* | rtems/libbsd: Update to origin/5-freebsd12 HEAD. | Chris Johns | 2020-04-06 | 1 | -4/+4 |
* | rtems/kernel: Update to origin/master HEAD. | Chris Johns | 2020-04-06 | 1 | -2/+2 |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-04-06 | 3 | -8/+8 |
* | databases/sqlite: Update to 3.31.1 | Jonathan Brandmeyer | 2020-04-02 | 3 | -28/+24 |
| | | | | closes #3927. | ||||
* | rtems/libbsd: Update to the latest 5-freebsd12 branch head. | Chris Johns | 2020-03-30 | 1 | -2/+2 |
* | rtems/kernel: Update to the latest master. | Chris Johns | 2020-03-30 | 1 | -2/+2 |
* | 5/rtems-tools: Update to pick up rtems-test fixes for GDB | Chris Johns | 2020-03-30 | 1 | -2/+2 |
* | 5: Update rtems-tools | Sebastian Huber | 2020-03-23 | 1 | -2/+2 |
| | | | | | | Pick up new features for rtems-record-lttng. Update #3904. | ||||
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-03-23 | 3 | -8/+8 |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-03-17 | 3 | -10/+10 |
* | 5: Update Newlib | Sebastian Huber | 2020-03-17 | 7 | -5/+75 |
| | | | | Pick up fix for crt0.c. | ||||
* | Update gcc to 9.3.0 for targets using 9.2.0 | Joel Sherrill | 2020-03-12 | 4 | -3/+31 |
* | Update newlib to c56f53a | Joel Sherrill | 2020-03-12 | 7 | -5/+75 |
| | | | | This is primarily to pick up the bug fix to have i386 fenv methods. |
