* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-10-15 | 3 | -6/+9 |
| | | | | Close #4741. | ||||
* | 6: Update GCC 10 and 12 | Sebastian Huber | 2022-10-14 | 2 | -4/+6 |
| | | | | Update #4741. | ||||
* | 6/7: Update Newlib | Sebastian Huber | 2022-10-14 | 4 | -8/+11 |
* | rtems-tools-6.cfg: Bump tools hash | Ryan Long | 2022-10-13 | 1 | -2/+2 |
* | rtems-gcc-12-newlib-head.cfg: Bump newlib hash to get extern C on resource.h | Joel Sherrill | 2022-09-26 | 1 | -2/+3 |
* | 6: Update GCC 10 and 12 | Sebastian Huber | 2022-09-24 | 2 | -4/+4 |
* | 6/7: Update Newlib | Sebastian Huber | 2022-09-24 | 4 | -8/+8 |
| | | | | This fixes a setjmp() and longjmp() issue for the 64-bit powerpc target. | ||||
* | rtems-tools-6.cfg: Correct hash | Joel Sherrill | 2022-09-21 | 1 | -1/+1 |
* | rtems-tools-6.cfg: Bump hash to avoid stray comma in aarch64.ini ↵ | Joel Sherrill | 2022-09-21 | 1 | -1/+1 |
| | | | | configuration for bsp-builder | ||||
* | rtems/kernel: Update to the latest | Chris Johns | 2022-09-21 | 1 | -2/+2 |
| | | | | - Addition of the Polarfire Icicle BSP | ||||
* | rtems-tools-6.cfg: Bump hash to update BSP list | Joel Sherrill | 2022-09-19 | 1 | -2/+2 |
* | testproc/gsed: Do not use %include with internal builds | Chris Johns | 2022-09-16 | 1 | -1/+2 |
* | devel/gcc: Check and build GNU sed if not available on build host | Chris Johns | 2022-09-14 | 1 | -0/+5 |
| | | | | Closes #2300 | ||||
* | rtems/jpeg: Update the checksum | Chris Johns | 2022-09-09 | 1 | -2/+2 |
* | rtems/bsps: Update the buildset defines to be arch/bsp | Chris Johns | 2022-09-09 | 14 | -42/+14 |
| | | | | - Remove the unused defines | ||||
* | rtems/packages: Remove lwip from the generic packages | Chris Johns | 2022-09-09 | 1 | -1/+0 |
| | | | | - Networking stacks are selected at the BSP level | ||||
* | rtems/kernel: Update the confg file support | Chris Johns | 2022-09-09 | 1 | -119/+121 |
| | | | | | | | | - Check for config file tests and install if enabled - Support buildset BSP options defines if building a single BSP - Remove bootstrap and autotools fragments | ||||
* | rtems/rtems-bsp: Support a kernel configuration file | Chris Johns | 2022-09-09 | 1 | -15/+31 |
| | | | | - Support a single BSP defined in a kernel config file | ||||
* | rtems/kernel: Support a list of BSPs as arch/bsp | Chris Johns | 2022-09-09 | 1 | -27/+17 |
* | rtems/libbsd: Update to the latest on the 6-freebsd-12 branch | Chris Johns | 2022-09-09 | 1 | -2/+2 |
* | rtems/kernel: Update to the latest kernel | Chris Johns | 2022-09-09 | 1 | -3/+3 |
| | | | | - Update hash file extension | ||||
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-09-08 | 3 | -6/+6 |
* | 6: Update GCC 10 and 12 | Sebastian Huber | 2022-09-08 | 2 | -10/+4 |
| | | | | Update #4712. | ||||
* | 6/7: Update Newlib | Sebastian Huber | 2022-09-08 | 4 | -8/+8 |
* | config: Various updates to fix downloading of sources | Chris Johns | 2022-08-17 | 3 | -4/+9 |
* | 6: Enable some libstdc++ features | Sebastian Huber | 2022-08-17 | 2 | -0/+7 |
| | | | | | | | | | Enable TLS support for all RTEMS targets except bfin, lm32, m68k, mips, moxie, or1k, and v850. For all RTEMS targets, define HAVE_ALIGNED_ALLOC, HAVE_AT_QUICK_EXIT, HAVE_LINK, HAVE_QUICK_EXIT, HAVE_READLINK, HAVE_SETENV, HAVE_SLEEP, HAVE_STRERROR_L, HAVE_SYMLINK, HAVE_TRUNCATE, and HAVE_USLEEP. Update #4668. | ||||
* | 6: Use local-exec TLS model by default | Sebastian Huber | 2022-08-08 | 2 | -0/+7 |
| | | | | Update #4560. | ||||
* | 6/7: Update to the latest rtems-tools | Sebastian Huber | 2022-08-08 | 1 | -2/+2 |
| | | | | Update 4671. | ||||
* | rtems-tools-6.cfg: Bump hash | Ryan Long | 2022-08-01 | 1 | -2/+2 |
* | 6/7: Update to the latest rtems-tools | Sebastian Huber | 2022-07-27 | 1 | -2/+2 |
* | 6/7: Use TLS in Newlib for some targets by default | Sebastian Huber | 2022-07-21 | 12 | -0/+12 |
| | | | | | | | | Use the --enable-newlib-reent-thread-local (_REENT_THREAD_LOCAL_STORAGE) Newlib configuration option on the aarch64, arm, nios2, powerpc, riscv, and sparc targets by default. Update #4560. | ||||
* | 6/7: Update Newlib | Sebastian Huber | 2022-07-21 | 4 | -7/+33 |
| | | | | | | | This makes the --enable-newlib-reent-thread-local (_REENT_THREAD_LOCAL_STORAGE) Newlib configuration option available. Update #4560. | ||||
* | gcc12/libstdc++: Fix lifetime bugs for non-TLS eh_globals | Chris Johns | 2022-07-06 | 1 | -8/+21 |
| | | | | | | | - This is the fix from PR105880: https://gcc.gnu.org/bugzilla/attachment.cgi?id=53103 Closes #4661 | ||||
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-07-01 | 3 | -6/+6 |
* | 6/7: Update Newlib | Sebastian Huber | 2022-07-01 | 3 | -6/+6 |
| | | | | | | This Newlib update fixes a FreeBSD kernel space issue with <sys/cpuset.h>. Update #4667. | ||||
* | 6: Add GCC 10.4 with Newlib e7ffbdb | Sebastian Huber | 2022-06-29 | 1 | -0/+27 |
* | 6: Back port v8 of gcov improvements to GCC 10 | Sebastian Huber | 2022-06-29 | 1 | -2/+2 |
| | | | | Update #4196. | ||||
* | 6/7: Update Newlib | Sebastian Huber | 2022-06-24 | 3 | -6/+6 |
| | | | | | | This Newlib update fixes a namespace pollution issue with <sys/bitset.h>. Close #4667. | ||||
* | 6: Update GCC 10 and 12 | Sebastian Huber | 2022-06-22 | 2 | -4/+4 |
* | 6: Back port v6 of gcov improvements to GCC 10 | Sebastian Huber | 2022-06-21 | 1 | -2/+2 |
* | 6/tools: Update to the latest commit | Chris Johns | 2022-05-18 | 1 | -2/+2 |
* | ISL, MPC, MPFR: fix configuration issues on ARM64/Darwin host | Karel Gardas | 2022-05-17 | 1 | -0/+14 |
| | | | | | | Updates #4657. Sponsored-By: Precidata | ||||
* | 7: Remove superfluous GCC patch | Sebastian Huber | 2022-05-09 | 1 | -3/+0 |
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-05-09 | 3 | -6/+6 |
* | 6: Update to GCC 12 | Sebastian Huber | 2022-05-09 | 2 | -1/+27 |
* | sb/setbuilder: Control buildsets using the --with-* command line option | Chris Johns | 2022-05-05 | 3 | -22/+42 |
| | | | | | | | | | | - Expand macros in buildset file names - Add support to buildsets for `%defineifnot` - Update 6 and 7 to support command line build overrides Closes #4646 | ||||
* | 7: Back port gcov-tool merge-stream to GCC 12 | Sebastian Huber | 2022-05-04 | 1 | -0/+3 |
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-05-04 | 3 | -6/+6 |
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-04-27 | 3 | -6/+6 |
