Adding the host name results in the tar files created by the
--bset-tar-file and --pkg-tar-files to contain the host name.
This is useful when building Cxc packages.
Add a suitable hash for the build to proceed.
Closes #2202.
Add support to build on FreeBSD 10.
The CAN support is broken on a recent qemu and needs updating so has
been removed from the build.
This patch adds support to enable RSB to build or1ksim emulator
(the main OpenRISC 1000 simulator) from latest or1ksim github repo.
Add the hash for automake.
File download by http, ftp, pw support checksum. The %hash
directive provides a means of setting a hash used to
checksum the file.
Files on disk or just downloaded are checked.
Add a build set file for libusb.
Remove the 'opt' from various macros and shell variables.
Add pkgconfig to the checks to make it clear the check is a
pkgconfig check.
Add NTP support as the first package to be built using the RSB.
Split the RTEMS URL's out from the base bset file into a separate
file that be included by other files.
Add an RTEMS BSP configuration file to help abstract the process
of building 3rd party packages.
Clean the cross and canadian cross support up so we can cleanly support
cross and canadian cross building.
Refactor the pkgconfig support and clean up the PC file handling of
loading modules.
Add support for %{?..} to return false if a macro is %{nil}.
Add %{pkgconfig ..} support to allow better control of access RTEMS
pkgconfig files.
Hack round the FreeBSD iconv support in Freebsd 10. In 10 libc now
supports iconv however iconv.h is present under /usr/local.
Start to add support to build qemu for MinGW via a Cxc. This is a
work in progress and contains lots of hidden traps.
In config.py separate out of the canadian build status.
Add the extra actions: ccflags, cflags, ldflags and libs to allow the
fetching of these from pkg-config files.
Update configuration to build on FreeBSD. This is based on pkg-config
detecting the packages installed on the host.
Qemu requires gettext, glib, libffi, and pixman. DTC is built
as a submodule.
On Mavrick provide a pkg-config command so avoid needing a pkgconfig.
The one here is only just good enough to work.
Provide an internal autotools build including libtool so qemu can
be built from git.
Add support to build bare metal tools such as sparc-elf.
Signed-off-by: Chris Johns <chrisj@rtems.org>
Rework the RTEMS build set files to point to the new location.
Move the files into devel, this follows the ports naming in
FreeBSD.
Update the macros, defaults, and options to support this.
