* | waf: Allow to add libs per test. | Christian Mauderer | 2018-05-04 | 1 | -1/+3 |
| | | | | Update #3419. | ||||
* | waf: Generate a rtems/bsd/modules.h | Christian Mauderer | 2018-05-03 | 1 | -0/+32 |
| | | | | | | | | The generated file defines a RTEMS_BSD_MODULE_xxx for each enabled module. That is usefull for conditional compilation depending on whether a module is build not. Update #3351. | ||||
* | waf: Fix source code generators. | Christian Mauderer | 2018-05-03 | 1 | -6/+6 |
| | | | | | There have been some bugs with the strings left from the transition to directly building from libbsd.py. | ||||
* | waf: Fix usage of build-include from config. | Christian Mauderer | 2018-05-03 | 1 | -2/+6 |
* | Use network services from RTEMS | Sebastian Huber | 2018-04-30 | 1 | -1/+1 |
| | | | | Close #3419. | ||||
* | waf: Add configurations with different modules. | Christian Mauderer | 2018-04-10 | 1 | -9/+0 |
| | | | | Update #3351 | ||||
* | waf: Fix freebsd-to-rtems.py. | Christian Mauderer | 2018-04-10 | 1 | -156/+0 |
| | | | | Update #3351 | ||||
* | waf: Refactor libbsd.py to support per module generation. | Chris Johns | 2018-04-10 | 1 | -1/+3 |
| | | | | | | This change allows us to control the modules we want to build. Update #3351 | ||||
* | waf: Support building from libbsd.py directly from waf. | Chris Johns | 2018-04-10 | 1 | -0/+644 |
Remove the need to generate a waf script. Move various pieces of data from the builder code to libbsd.py and make it configuration data. Update #3351 |
