* | testsuite/pf01: Add test that links PF. | Christian Mauderer | 2016-08-03 | 1 | -0/+47 |
* | testsuite/cdev01: Add test for cdev functions. | Christian Mauderer | 2016-08-03 | 3 | -0/+352 |
* | SOCKETPAIR(2): Port to RTEMS | Sebastian Huber | 2015-11-16 | 1 | -0/+48 |
* | media01: Add network and SMP support | Sebastian Huber | 2015-09-11 | 1 | -3/+44 |
* | Update due to header guard changes | Sebastian Huber | 2015-07-23 | 1 | -1/+1 |
* | condvar01: Initialize mutex | Sebastian Huber | 2015-06-23 | 1 | -0/+1 |
* | if_dwc: Add Altera Cyclone V support | Sebastian Huber | 2015-04-01 | 1 | -1/+3 |
* | tests: Support DEFAULT_EARLY_INITIALIZATION | Sebastian Huber | 2015-04-01 | 1 | -0/+4 |
* | LAGG(4): Enable and test | Sebastian Huber | 2015-03-30 | 3 | -0/+100 |
* | VLAN(4): Enable and test | Sebastian Huber | 2015-03-30 | 3 | -0/+119 |
* | tests: Fix define usage | Sebastian Huber | 2015-03-30 | 1 | -4/+4 |
* | media01: New test | Sebastian Huber | 2015-03-26 | 2 | -0/+164 |
* | mmc: Import MMC/SDCard support from libusb | Sebastian Huber | 2015-03-26 | 1 | -0/+1 |
* | smp01: New test | Sebastian Huber | 2015-03-24 | 1 | -0/+289 |
* | tests: Add PROFREPORT shell command | Sebastian Huber | 2015-03-06 | 1 | -0/+1 |
* | Add zerocopy sendto | Sebastian Huber | 2015-02-13 | 1 | -0/+243 |
* | Add Xilinx Zynq BSP support | Sebastian Huber | 2015-01-21 | 1 | -0/+2 |
* | Add and use rtems_bsd_get_task_stack_size() | Sebastian Huber | 2015-01-20 | 1 | -1/+3 |
* | HOSTNAME(1): Import from FreeBSD | Sebastian Huber | 2014-11-05 | 2 | -0/+2 |
* | foobarclient: Use rtems_mdns_initialize() | Sebastian Huber | 2014-11-04 | 1 | -22/+10 |
* | foobarserver: Set hostname | Sebastian Huber | 2014-10-31 | 1 | -0/+5 |
* | foobarclient: Set and advertise hostname | Sebastian Huber | 2014-10-31 | 1 | -1/+6 |
* | Support sethostname() and gethostname() | Sebastian Huber | 2014-10-24 | 1 | -0/+20 |
* | SYSLOG(3): Replace implementation | Sebastian Huber | 2014-10-09 | 1 | -0/+24 |
| | | | | | Avoid potential buffer overflows on the stack. Expand the %m in the format string. | ||||
* | testsuite: Fix lo0 ifconfig error | Sebastian Huber | 2014-10-09 | 1 | -0/+1 |
| | | | | Avoid "ifa_del_loopback_route: deletion failed". | ||||
* | ppp: Port to new stack | Sebastian Huber | 2014-10-08 | 1 | -0/+281 |
* | testsuite: Add DEFAULT_NETWORK_NO_INTERFACE_0 | Sebastian Huber | 2014-10-08 | 1 | -0/+8 |
* | testsuite: Make similar to default-network-init.h | Sebastian Huber | 2014-10-08 | 1 | -27/+8 |
* | nexus: Use a linker set for the devices | Sebastian Huber | 2014-10-08 | 3 | -10/+2 |
* | Delete obsolete _bsd_nexus_devices | Sebastian Huber | 2014-10-08 | 2 | -18/+0 |
* | usb01: Update due to API changes | Sebastian Huber | 2014-09-30 | 1 | -2/+0 |
* | Delete rtems_bsd_thread_chain | Sebastian Huber | 2014-09-25 | 1 | -0/+1 |
| | | | | Rely on RTEMS object registration for threads. | ||||
* | Replace RTEMS objects with custom implementation | Sebastian Huber | 2014-09-23 | 3 | -6/+916 |
| | | | | | | | | Performance analysis revealed that the standard RTEMS objects are a major bottleneck. The object get mechanism and attribute checks at runtime have a significant overhead. Use a custom implementation for synchronization primitives. This drops also the size of the synchronization primitives considerably. | ||||
* | Disable IPsec | Sebastian Huber | 2014-09-23 | 1 | -3/+3 |
| | | | | | IPsec has a significant performance impact. Disable it for now since is only partially supported and untested. | ||||
* | ftpd01: Start shell only once | Sebastian Huber | 2014-09-18 | 1 | -11/+2 |
* | telnetd01: New test | Sebastian Huber | 2014-09-18 | 1 | -0/+78 |
* | Update due to workspace allocation changes | Sebastian Huber | 2014-05-14 | 1 | -39/+38 |
* | Update due to shell API changes | Sebastian Huber | 2014-04-17 | 1 | -1/+2 |
* | ftpd01: Use DHCP | Sebastian Huber | 2014-01-30 | 1 | -0/+1 |
* | mDNS: Add basic support | Sebastian Huber | 2014-01-30 | 2 | -0/+488 |
* | DHCPCD(8): Add basic support | Sebastian Huber | 2014-01-30 | 3 | -0/+160 |
* | arphole: New test | Sebastian Huber | 2014-01-30 | 1 | -0/+114 |
* | ftpd01: Update due to API changes | Sebastian Huber | 2014-01-30 | 1 | -34/+1 |
* | Add DEFAULT_NETWORK_SHELL | Sebastian Huber | 2014-01-30 | 1 | -0/+55 |
* | Add DEFAULT_NETWORK_NO_STATIC_IFCONFIG | Sebastian Huber | 2014-01-30 | 1 | -9/+34 |
* | Add and use RTEMS_BSD_ARGC() | Sebastian Huber | 2014-01-30 | 3 | -14/+10 |
* | UNIX(4): Import from FreeBSD | Sebastian Huber | 2014-01-16 | 4 | -1/+260 |
* | syscalls01: Include missing header file | Sebastian Huber | 2013-12-20 | 1 | -0/+1 |
* | Delete rtems_bsd_initialize_with_interrupt_server | Sebastian Huber | 2013-12-20 | 3 | -3/+3 |
| | | | | Move interrupt server initialization to nexus_probe(). | ||||
* | ftpd01: Add network shell commands | Sebastian Huber | 2013-12-20 | 1 | -2/+8 |
