* | EPOCH(9): Add epoch_drain_callbacks() | Sebastian Huber | 2019-07-09 | 1 | -0/+50 |
* | test/epoch01: Simplify | Sebastian Huber | 2019-07-09 | 1 | -48/+36 |
* | test/commands01: Fix sporadic test failures | Sebastian Huber | 2019-06-26 | 1 | -1/+29 |
* | test/program01: Fix sporadic test failures | Sebastian Huber | 2019-06-26 | 1 | -0/+8 |
* | config: Control the interface from the command line net config file. | Chris Johns | 2019-06-13 | 1 | -1/+1 |
* | Fix zero-copy mbuf support | Sebastian Huber | 2019-05-13 | 1 | -3/+3 |
| | | | | In 2017 there was a change in the mbuf API. | ||||
* | Update due to API changes | Sebastian Huber | 2019-04-11 | 2 | -2/+2 |
* | openssl02: Fix includes | Sebastian Huber | 2019-03-29 | 1 | -7/+3 |
* | bin/openssl: Port to RTEMS. | Christian Mauderer | 2019-03-28 | 1 | -0/+135 |
* | rcconf02: Reduce maximum connection counts | Sebastian Huber | 2019-03-11 | 1 | -2/+2 |
| | | | | This avoids a file descriptor exhaustion. | ||||
* | openssl01: Call standard initialization functions | Sebastian Huber | 2018-10-25 | 1 | -0/+5 |
* | openssl01: New test | Sebastian Huber | 2018-10-25 | 1 | -0/+139 |
* | ppp01: Use novj option on host side | Sebastian Huber | 2018-10-17 | 1 | -2/+3 |
| | | | | | | | | The VJ compression seems to be not supported by libbsd. Without this option the following errors show up on the host side: rcvd [LCP ProtRej id=0x75 00 2f 45 00 00 34 6b 9a 40 00 40 01 85 87 c0 a8 64 0b c0 a8 64 46 89 3c 00 15 2c 27 95 c2 0a 88 ...] Protocol-Reject for unsupported protocol 'VJ uncompressed TCP/IP' (0x2f) | ||||
* | Fix dhcpcd.conf content | Sebastian Huber | 2018-10-11 | 1 | -4/+4 |
| | | | | | Do not write '\0' characters to the file. This confuses the options parser. | ||||
* | Increase file descriptors in default network cfg | Sebastian Huber | 2018-10-10 | 1 | -1/+1 |
| | | | | Make sure we can start the Telnet server in the default configuration. | ||||
* | media01: Improve output messages | Sebastian Huber | 2018-09-25 | 1 | -12/+7 |
| | | | | | Use a single printf() call to avoid interference from other output. Do not print the listener argument. | ||||
* | Update to FreeBSD head 2018-09-17 | Sebastian Huber | 2018-09-21 | 1 | -6/+11 |
| | | | | | | Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319. Update #3472. | ||||
* | Update to FreeBSD head 2018-06-01 | Sebastian Huber | 2018-09-21 | 3 | -0/+3017 |
| | | | | | | Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9. Update #3472. | ||||
* | syscalls01: Fix for IPSEC enabled | Sebastian Huber | 2018-08-28 | 1 | -0/+5 |
* | tests/termios: Fix warnings | Sebastian Huber | 2018-08-20 | 1 | -3/+11 |
* | testsuite/ipsec01: Add. | Christian Mauderer | 2018-08-02 | 4 | -0/+347 |
* | ipsec-tools: Port libipsec, setkey and racoon. | Christian Mauderer | 2018-08-02 | 1 | -0/+9 |
| | | | | | Note that this replaces the libipsec from FreeBSD with the one provided by ipsec-tools. | ||||
* | selectpollkqueue01: Invalidate file descriptor | Sebastian Huber | 2018-07-26 | 1 | -0/+6 |
| | | | | This is not a functional change or a fix. | ||||
* | Fix sporadic test failures via uma_timeout() | Sebastian Huber | 2018-07-26 | 2 | -13/+15 |
* | syscalls01: Fix sporadic test failures | Sebastian Huber | 2018-07-02 | 1 | -0/+14 |
* | dhcpcd: Add hooks | Sebastian Huber | 2018-05-08 | 1 | -1/+23 |
* | dhcpcd: Add rtems_dhcpcd_start() | Sebastian Huber | 2018-05-08 | 1 | -32/+5 |
| | | | | Use it throughout to start the DHCP client (dhcpcd). | ||||
* | buildset: Add minimal and everything config. | Christian Mauderer | 2018-05-03 | 3 | -6/+41 |
| | | | | | | | | | | | | This adds two new buildset configurations: One that leaves out as much features as possible and one that enables all features. For the default configuration WiFi support is now disabled. To disable IPv6 for the minimal configuration, all -DINET6 are eliminated in libbsd.py. They are now replaced by a #ifdef that checks for RTEMS_BSD_MODULE_NETINET6 instead. Close #3351. | ||||
* | Add DHCP clientid to test default network init | Sebastian Huber | 2018-04-30 | 1 | -8/+12 |
* | CRYPTO(4): Port to RTEMS | Sebastian Huber | 2018-03-28 | 1 | -0/+198 |
* | mutex: Use panic() after ISR lock release | Sebastian Huber | 2018-03-13 | 1 | -1/+99 |
| | | | | | | Using panic() with interrupts disabled could lead to an additional error (INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT) due to a potentially blocking output. | ||||
* | tests: Fix configuration dependencies | Sebastian Huber | 2018-02-05 | 2 | -0/+6 |
* | Revert "RWLOCK(9): Add reader/writer lock implementation" | Sebastian Huber | 2017-11-17 | 1 | -275/+33 |
| | | | | | | This was accidentally committed. This reverts commit 97a98f6cd767b3a68279890488c7b451788f84f4. | ||||
* | RWLOCK(9): Add reader/writer lock implementation | Sebastian Huber | 2017-11-16 | 1 | -33/+275 |
* | Add wpa_supplicant_fork command. | Sichen Zhao | 2017-11-10 | 1 | -1/+2 |
| | | | | Add fork command for wpa supplicant to start a new task. | ||||
* | Add wpa_supplicant command in test suite. | Sichen Zhao | 2017-11-10 | 2 | -2/+4 |
| | | | | Add wpa supplicant command in media01. | ||||
* | tests/syscalls01: Fix shutdown() test | Sebastian Huber | 2017-11-10 | 1 | -1/+14 |
| | | | | The socket must be connected for a shutdown(). | ||||
* | Add rtems_bsd_ifconfig_lo0() | Sebastian Huber | 2017-11-10 | 1 | -32/+1 |
* | tests/syscall01: Update error values | Sebastian Huber | 2017-11-10 | 1 | -39/+39 |
| | | | | FreeBSD changed the error values. | ||||
* | tests/mutex01: Fix mtx_recursed() usage | Sebastian Huber | 2017-11-09 | 1 | -32/+32 |
* | tests/program01: Fix test name | Sebastian Huber | 2017-11-09 | 1 | -1/+1 |
* | Import DPAA driver snapshot | Sebastian Huber | 2017-10-23 | 1 | -0/+6 |
| | | | | | | | | | | Imported from Freescale Linux repository git://git.freescale.com/ppc/upstream/linux.git commit 2774c204cd8bfc56a200ff4dcdfc9cdf5b6fc161. Linux compatibility layer is partly from FreeBSD. | ||||
* | Add CPUINFO command to default network init | Sebastian Huber | 2017-10-20 | 1 | -0/+1 |
* | media01: Scale with processor count | Sebastian Huber | 2017-10-20 | 1 | -2/+6 |
* | tests: Remove obsolete config defines | Sebastian Huber | 2017-10-20 | 4 | -12/+0 |
* | Include missing <string.h> and <limits.h> | Sebastian Huber | 2017-08-25 | 11 | -21/+29 |
| | | | | | | | Fix warnings. Update #2132. Update #2133. | ||||
* | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 2017-06-08 | 6 | -14/+9 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 17 | -98/+19 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Add tests for USB keyboard and mouse as well as EVDEV | Kevin Kirspel | 2017-05-19 | 3 | -0/+1325 |
* | Adding USB Serial test | Kevin Kirspel | 2017-05-12 | 1 | -0/+329 |
