* | Delete dummy IRQ support | Sebastian Huber | 2016-04-27 | 1 | -4/+0 |
| | | | | | Architectures and BSPs which want to use libbsd must provide the required interfaces. | ||||
* | Add root bus support functions | Sebastian Huber | 2016-04-26 | 1 | -0/+1 |
* | Initialize interrupt server early | Sebastian Huber | 2016-04-26 | 1 | -0/+1 |
| | | | | This enables its use before the Nexus device exists. | ||||
* | waf: Check for no FreeBSD options being supplied. | Chris Johns | 2016-04-26 | 1 | -2/+3 |
* | waf: Add the ability to set FreeBSD options on the configure command line. | Chris Johns | 2016-04-23 | 1 | -33/+39 |
| | | | | | Add --freebsd-options to add specific FreeBSD compile time options to the build. This is a developer tool. | ||||
* | waf: Move the generated content to libbsd_waf.py. | Chris Johns | 2016-04-20 | 1 | -0/+1395 |
