* | Install Linux header files | Sebastian Huber | 2017-10-23 | 1 | -0/+1 |
* | waf: Install arch-specific header files | Sebastian Huber | 2017-10-23 | 1 | -4/+6 |
* | Add rtems_bsd_set_if_input() | Sebastian Huber | 2017-10-23 | 1 | -0/+1 |
* | Linux update to 4.11-rc5 | Sebastian Huber | 2017-10-23 | 1 | -8/+2 |
| | | | | Linux baseline a71c9a1c779f2499fb2afc0553e543f18aff6edf (4.11-rc5). | ||||
* | Import DPAA driver snapshot | Sebastian Huber | 2017-10-23 | 1 | -1/+30 |
| | | | | | | | | | | Imported from Freescale Linux repository git://git.freescale.com/ppc/upstream/linux.git commit 2774c204cd8bfc56a200ff4dcdfc9cdf5b6fc161. Linux compatibility layer is partly from FreeBSD. | ||||
* | Import CRC32 support from FreeBSD | Sebastian Huber | 2017-10-20 | 1 | -0/+1 |
* | blist: Import from FreeBSD | Sebastian Huber | 2017-10-20 | 1 | -0/+1 |
* | Install libpcap header files | Sebastian Huber | 2017-10-16 | 1 | -0/+2 |
* | tcpdump: Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-10-11 | 1 | -2/+26 |
| | | | | | | Update tcpdump from Git mirror commit 99a648a912e81e29d9c4c159cbbe263462f2d719 to 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | Update libpcap to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-10-09 | 1 | -0/+1 |
| | | | | | | Update libpcap from Git mirror commit 99a648a912e81e29d9c4c159cbbe263462f2d719 to 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | Regenerate libbsd_waf.py | Sebastian Huber | 2017-10-09 | 1 | -1/+1 |
* | Allow to set optimization level during configure. | Christian Mauderer | 2017-10-02 | 1 | -1/+1 |
| | | | | | | This allows to set the optimization level for libbsd via a configure switch. Useful for building with for example no optimization during debug or with size optimization for space restricted targets. | ||||
* | ffec: Port to RTEMS | Sebastian Huber | 2017-09-27 | 1 | -0/+1 |
* | if_atsam: Allow fixed MII settings. | Christian Mauderer | 2017-09-22 | 1 | -0/+1 |
* | if-atsam: Port to rtems-libbsd. | Christian Mauderer | 2017-09-22 | 1 | -0/+1 |
* | Remove strtoimax() and strtoumax() | Sebastian Huber | 2017-08-22 | 1 | -2/+0 |
| | | | | This is now provided by Newlib. | ||||
* | Port openssl to RTEMS. | Sichen Zhao | 2017-08-20 | 1 | -16/+885 |
* | waf: Move glob operator ** to builder.py | Christian Mauderer | 2017-08-20 | 1 | -15/+15 |
| | | | | This allows a finer decision which headers should be installed. | ||||
* | waf_generator: Copy headers if necessary. | Christian Mauderer | 2017-08-20 | 1 | -0/+15 |
| | | | | | | | | | | | There are some cases, where a header is installed into a directory with a different name then it's source directory. In that case, the build might fail because the header is not found. One example would be the <openssl/opensslv.h>. The source for this file is in freebsd/crypto/openssl/crypto/opensslv.h. To allow the build to work in such cases too, copy such files into a temporary location in the build tree. | ||||
* | Port rtl8188eu driver to RTEMS. | Sichen Zhao | 2017-08-02 | 1 | -0/+1 |
| | | | | | Now USB dongle rtl8188eu can work as wlan client device. It can scan wifi, connect unencrypted wifi. | ||||
* | dev/rtwn: Import new files from FreeBSD. | Christian Mauderer | 2017-07-17 | 1 | -0/+10 |
* | Port am335x usb driver to RTEMS. | Sichen Zhao | 2017-07-13 | 1 | -0/+6 |
| | | | | | | Add FDT and umass support for am335x USB driver. Now RTEMS can mount and open USB disk. | ||||
* | Update scripts to include support for input devices - USB Keyboard, USB ↵ | Kevin Kirspel | 2017-05-19 | 1 | -0/+43 |
| | | | | mouse, touch, and EVDEV | ||||
* | Updating scripts for USB Serial Drivers | Kevin Kirspel | 2017-05-12 | 1 | -0/+30 |
* | Updating scripts for FREEBSD TTY support | Kevin Kirspel | 2017-05-11 | 1 | -0/+97 |
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 1 | -2/+5 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | if_tsec: Enable FDT support | Sebastian Huber | 2017-03-08 | 1 | -0/+1 |
* | FDT(4): Port to RTEMS | Sebastian Huber | 2017-03-08 | 1 | -0/+10 |
* | Add poll() and select() support for Termios | Sebastian Huber | 2017-02-28 | 1 | -0/+1 |
* | C11/C++11 are the default for the RTEMS 4.12 GCC | Sebastian Huber | 2017-02-21 | 1 | -2/+2 |
* | Port LPC32XX Ethernet and USB OHCI to RTEMS | Kevin Kirspel | 2017-02-14 | 1 | -1/+4 |
* | freebsd/wlanstats: Port to FreeBSD. | Christian Mauderer | 2017-01-17 | 1 | -0/+5 |
* | wlan/run: Add firmware. | Christian Mauderer | 2017-01-17 | 1 | -0/+1 |
* | rtwn: Port to RTEMS | Christian Mauderer | 2017-01-17 | 1 | -0/+80 |
* | lib80211/regdomain: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 1 | -0/+1 |
* | ifconfig/wlan, expat, lib80211: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 1 | -24/+42 |
* | Port USB and USB WLAN. | Christian Mauderer | 2017-01-17 | 1 | -0/+22 |
* | firmware: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 1 | -0/+1 |
* | Port IEEE 802.11. | Christian Mauderer | 2017-01-17 | 1 | -0/+39 |
* | Use thread name support | Sebastian Huber | 2017-01-13 | 1 | -1/+0 |
| | | | | Update #2858. | ||||
* | ARP(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -1/+3 |
* | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 2017-01-10 | 1 | -0/+1 |
| | | | | Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | ||||
* | VMSTAT(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -1/+3 |
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 1 | -59/+82 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | PIPE(2): Port to RTEMS | Kevin Kirspel | 2016-12-23 | 1 | -0/+1 |
* | Add a RTEMS Debugger TCP remote transport. | Chris Johns | 2016-11-29 | 1 | -7/+20 |
| | | | | | | | The patch also adds support to libbsd's build system making source conditional on a configure check. The debugger support is not available on all architectures and this feature lets us test if is avaliable. | ||||
* | Use -Wno-pointer-sign | Sebastian Huber | 2016-11-14 | 1 | -0/+1 |
| | | | | Pointer sign warnings are quite common in FreeBSD code. | ||||
* | SDHCI(4): Delete | Sebastian Huber | 2016-11-09 | 1 | -1/+0 |
| | | | | | Delete heavily modified SDHCI(4) support. It must be re-imported from a later FreeBSD version on demand. | ||||
* | Remove AppleTalk support | Sebastian Huber | 2016-10-13 | 1 | -11/+0 |
| | | | | Prepare update to FreeBSD 11. | ||||
* | usb01: Simplify test program | Sebastian Huber | 2016-09-28 | 1 | -2/+1 |
