* | Add rtems_bsd_ifconfig() | Sebastian Huber | 2018-01-23 | 1 | -0/+1 |
* | openssl: Remove superfluous file | Sebastian Huber | 2018-01-08 | 1 | -1/+0 |
* | Add rtems_bsd_initialize_dhcp() | Sebastian Huber | 2017-12-05 | 1 | -0/+1 |
* | Revert "RWLOCK(9): Add reader/writer lock implementation" | Sebastian Huber | 2017-11-17 | 1 | -1/+0 |
| | | | | | | This was accidentally committed. This reverts commit 97a98f6cd767b3a68279890488c7b451788f84f4. | ||||
* | RWLOCK(9): Add reader/writer lock implementation | Sebastian Huber | 2017-11-16 | 1 | -0/+1 |
* | wpa: Port to new files to RTEMS. | Christian Mauderer | 2017-11-10 | 1 | -0/+4 |
* | at91_mci: Port to RTEMS and adapt for atsam. | Christian Mauderer | 2017-11-10 | 1 | -1/+2 |
* | saf1761_otg: Port to RTEMS. | Christian Mauderer | 2017-11-10 | 1 | -0/+2 |
* | wpa_supplicant: Add lock. | Christian Mauderer | 2017-11-10 | 1 | -0/+1 |
* | Add wpa_supplicant_fork command. | Sichen Zhao | 2017-11-10 | 1 | -0/+1 |
| | | | | Add fork command for wpa supplicant to start a new task. | ||||
* | Port wpa supplicant to RTEMS. | Sichen Zhao | 2017-11-10 | 1 | -4/+111 |
| | | | | Add wpa_supplicant lib support and shell command support in RTEMS. | ||||
* | Port BBB sd driver files to RTEMS. | Sichen Zhao | 2017-11-10 | 1 | -0/+8 |
| | | | | So BBB can mount and read eMMC and SD card. | ||||
* | Add rtems_bsd_ifconfig_lo0() | Sebastian Huber | 2017-11-10 | 1 | -0/+1 |
* | Install Linux header files | Sebastian Huber | 2017-10-23 | 1 | -0/+1 |
* | waf: Install arch-specific header files | Sebastian Huber | 2017-10-23 | 1 | -4/+6 |
* | Add rtems_bsd_set_if_input() | Sebastian Huber | 2017-10-23 | 1 | -0/+1 |
* | Linux update to 4.11-rc5 | Sebastian Huber | 2017-10-23 | 1 | -8/+2 |
| | | | | Linux baseline a71c9a1c779f2499fb2afc0553e543f18aff6edf (4.11-rc5). | ||||
* | Import DPAA driver snapshot | Sebastian Huber | 2017-10-23 | 1 | -1/+30 |
| | | | | | | | | | | Imported from Freescale Linux repository git://git.freescale.com/ppc/upstream/linux.git commit 2774c204cd8bfc56a200ff4dcdfc9cdf5b6fc161. Linux compatibility layer is partly from FreeBSD. | ||||
* | Import CRC32 support from FreeBSD | Sebastian Huber | 2017-10-20 | 1 | -0/+1 |
* | blist: Import from FreeBSD | Sebastian Huber | 2017-10-20 | 1 | -0/+1 |
* | Install libpcap header files | Sebastian Huber | 2017-10-16 | 1 | -0/+2 |
* | tcpdump: Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-10-11 | 1 | -2/+26 |
| | | | | | | Update tcpdump from Git mirror commit 99a648a912e81e29d9c4c159cbbe263462f2d719 to 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | Update libpcap to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-10-09 | 1 | -0/+1 |
| | | | | | | Update libpcap from Git mirror commit 99a648a912e81e29d9c4c159cbbe263462f2d719 to 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | Regenerate libbsd_waf.py | Sebastian Huber | 2017-10-09 | 1 | -1/+1 |
* | Allow to set optimization level during configure. | Christian Mauderer | 2017-10-02 | 1 | -1/+1 |
| | | | | | | This allows to set the optimization level for libbsd via a configure switch. Useful for building with for example no optimization during debug or with size optimization for space restricted targets. | ||||
* | ffec: Port to RTEMS | Sebastian Huber | 2017-09-27 | 1 | -0/+1 |
* | if_atsam: Allow fixed MII settings. | Christian Mauderer | 2017-09-22 | 1 | -0/+1 |
* | if-atsam: Port to rtems-libbsd. | Christian Mauderer | 2017-09-22 | 1 | -0/+1 |
* | Remove strtoimax() and strtoumax() | Sebastian Huber | 2017-08-22 | 1 | -2/+0 |
| | | | | This is now provided by Newlib. | ||||
* | Port openssl to RTEMS. | Sichen Zhao | 2017-08-20 | 1 | -16/+885 |
* | waf: Move glob operator ** to builder.py | Christian Mauderer | 2017-08-20 | 1 | -15/+15 |
| | | | | This allows a finer decision which headers should be installed. | ||||
* | waf_generator: Copy headers if necessary. | Christian Mauderer | 2017-08-20 | 1 | -0/+15 |
| | | | | | | | | | | | There are some cases, where a header is installed into a directory with a different name then it's source directory. In that case, the build might fail because the header is not found. One example would be the <openssl/opensslv.h>. The source for this file is in freebsd/crypto/openssl/crypto/opensslv.h. To allow the build to work in such cases too, copy such files into a temporary location in the build tree. | ||||
* | Port rtl8188eu driver to RTEMS. | Sichen Zhao | 2017-08-02 | 1 | -0/+1 |
| | | | | | Now USB dongle rtl8188eu can work as wlan client device. It can scan wifi, connect unencrypted wifi. | ||||
* | dev/rtwn: Import new files from FreeBSD. | Christian Mauderer | 2017-07-17 | 1 | -0/+10 |
* | Port am335x usb driver to RTEMS. | Sichen Zhao | 2017-07-13 | 1 | -0/+6 |
| | | | | | | Add FDT and umass support for am335x USB driver. Now RTEMS can mount and open USB disk. | ||||
* | Update scripts to include support for input devices - USB Keyboard, USB ↵ | Kevin Kirspel | 2017-05-19 | 1 | -0/+43 |
| | | | | mouse, touch, and EVDEV | ||||
* | Updating scripts for USB Serial Drivers | Kevin Kirspel | 2017-05-12 | 1 | -0/+30 |
* | Updating scripts for FREEBSD TTY support | Kevin Kirspel | 2017-05-11 | 1 | -0/+97 |
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 1 | -2/+5 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | if_tsec: Enable FDT support | Sebastian Huber | 2017-03-08 | 1 | -0/+1 |
* | FDT(4): Port to RTEMS | Sebastian Huber | 2017-03-08 | 1 | -0/+10 |
* | Add poll() and select() support for Termios | Sebastian Huber | 2017-02-28 | 1 | -0/+1 |
* | C11/C++11 are the default for the RTEMS 4.12 GCC | Sebastian Huber | 2017-02-21 | 1 | -2/+2 |
* | Port LPC32XX Ethernet and USB OHCI to RTEMS | Kevin Kirspel | 2017-02-14 | 1 | -1/+4 |
* | freebsd/wlanstats: Port to FreeBSD. | Christian Mauderer | 2017-01-17 | 1 | -0/+5 |
* | wlan/run: Add firmware. | Christian Mauderer | 2017-01-17 | 1 | -0/+1 |
* | rtwn: Port to RTEMS | Christian Mauderer | 2017-01-17 | 1 | -0/+80 |
* | lib80211/regdomain: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 1 | -0/+1 |
* | ifconfig/wlan, expat, lib80211: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 1 | -24/+42 |
* | Port USB and USB WLAN. | Christian Mauderer | 2017-01-17 | 1 | -0/+22 |
