* | libbsd.txt: Update version info and manpage links. | Christian Mauderer | 2018-08-06 | 1 | -22/+28 |
| | | | | | The information is clearly outdated. This patch updates it to the latest release. | ||||
* | libbsd.txt: Add ipsec. | Christian Mauderer | 2018-08-02 | 1 | -0/+128 |
* | buildset: Add minimal and everything config. | Christian Mauderer | 2018-05-03 | 1 | -3/+14 |
| | | | | | | | | | | | | This adds two new buildset configurations: One that leaves out as much features as possible and one that enables all features. For the default configuration WiFi support is now disabled. To disable IPv6 for the minimal configuration, all -DINET6 are eliminated in libbsd.py. They are now replaced by a #ifdef that checks for RTEMS_BSD_MODULE_NETINET6 instead. Close #3351. | ||||
* | waf: Support building from libbsd.py directly from waf. | Chris Johns | 2018-04-10 | 1 | -5/+5 |
| | | | | | | | | | Remove the need to generate a waf script. Move various pieces of data from the builder code to libbsd.py and make it configuration data. Update #3351 | ||||
* | vprintf: Add handler that mutes all output. | Christian Mauderer | 2018-03-23 | 1 | -0/+24 |
| | | | | | This adds a vprintf handler that can be used to suppress all outputs of the libbsd. | ||||
* | config.inc: Remove unused values. | Christian Mauderer | 2018-03-22 | 1 | -15/+7 |
* | libbsd.txt: Describe current state of WLAN. | Christian Mauderer | 2017-11-10 | 1 | -0/+52 |
* | Add CONTRIBUTING.md | Sebastian Huber | 2017-06-26 | 1 | -281/+0 |
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 1 | -1/+1 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | rtwn: Port to RTEMS | Christian Mauderer | 2017-01-17 | 1 | -0/+2 |
* | rtwn: Import from FreeBSD. | Christian Mauderer | 2017-01-17 | 1 | -2/+0 |
* | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 2017-01-10 | 1 | -1/+1 |
| | | | | Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | ||||
* | Update to FreeBSD head 2016-12-10 | Sebastian Huber | 2017-01-10 | 1 | -1/+1 |
| | | | | Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c. | ||||
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 1 | -4/+1 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | userspace-header-gen.py: Simplify program ports | Christian Mauderer | 2017-01-10 | 1 | -17/+26 |
* | usb: Update to FreeBSD trunk 2016-08-23 | Sebastian Huber | 2016-08-23 | 1 | -1/+1 |
| | | | | FreeBSD trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | doc: Update rules to modify FreeBSD code | Sebastian Huber | 2016-08-23 | 1 | -3/+14 |
* | mmc: Update to FreeBSD trunk 2016-08-23 | Sebastian Huber | 2016-08-23 | 1 | -0/+1 |
* | doc: Update rules to modify FreeBSD code | Sebastian Huber | 2016-08-19 | 1 | -0/+30 |
* | devfs: Add some notes on implementation. | Christian Mauderer | 2016-08-16 | 1 | -1/+9 |
* | doc: Add FreeBSD import version section | Sebastian Huber | 2016-08-10 | 1 | -0/+7 |
* | pf: Improve documentation regarding stack. | Christian Mauderer | 2016-08-08 | 1 | -2/+4 |
* | libbsd.txt: Add section describing PF. | Christian Mauderer | 2016-08-02 | 1 | -0/+44 |
* | libbsd.txt: Add guide for user space tools. | Christian Mauderer | 2016-08-02 | 1 | -0/+30 |
* | Add VDE and QEMU doco. | Chris Johns | 2016-06-27 | 1 | -0/+51 |
* | Fix spelling. | Chris Johns | 2016-06-27 | 1 | -1/+1 |
* | libbsd.txt: Clarify xilinx_zynq_a9_qemu usage | Sebastian Huber | 2016-06-13 | 1 | -10/+22 |
* | libbsd.txt: Fix format | Sebastian Huber | 2016-06-10 | 1 | -0/+1 |
* | Add a stats report command. | Chris Johns | 2016-05-31 | 1 | -2/+16 |
| | | | | The report shows the level of changes we have made to the FreeBSD code. | ||||
* | Add rc.conf documentation. | Chris Johns | 2016-05-18 | 1 | -1/+50 |
* | Add "How to import code from FreeBSD" | Sebastian Huber | 2016-05-06 | 1 | -0/+14 |
* | Add script to create the kernel namespace header | Sebastian Huber | 2016-05-06 | 1 | -0/+1 |
* | Add some doco on reverse and forward movement of the code. | Chris Johns | 2016-05-04 | 1 | -1/+26 |
* | Add RTEMS version support, update all python to 2 and 3. | Chris Johns | 2016-04-18 | 1 | -63/+29 |
| | | | | | | | | | | | | | Add support to force the RTEMS version. This remove the need for using the --rtems-version command line option if the automatic detection fails. Update all python code to support python 2 and 3. Update rtems_waf to the latest version to support the RTEMS version, check environment variables and to display the CC version. Sort all tests. I think the unsorted list is dependent on the version of python and so would result in repo noise as if it regenerted. | ||||
* | doc: Qemu network | Sebastian Huber | 2015-10-01 | 1 | -0/+9 |
* | doc: Add Qemu network setup | Sebastian Huber | 2015-10-01 | 1 | -0/+49 |
* | i386: Quick and dirty hack to get PCI working | Sebastian Huber | 2015-09-30 | 1 | -0/+2 |
* | libbsd.txt: Clarify rules to modify FreeBSD code | Sebastian Huber | 2015-07-15 | 1 | -3/+13 |
* | Update libbsd.txt with Xilinx Zynq TXCSUM and RXCSUM controls. | Chris Johns | 2015-06-22 | 1 | -1/+13 |
* | Revert "Return the default TX and RX hardware checksum for the Cadence ↵ | Chris Johns | 2015-06-22 | 1 | -13/+1 |
| | | | | | | | | | driver to off." This reverts commit 54fb9f01f86286ecea3093f6f524afec86d6313f. This change adds white space changes. A better solution is to revert the original change. | ||||
* | Return the default TX and RX hardware checksum for the Cadence driver to off. | Chris Johns | 2015-06-19 | 1 | -1/+13 |
| | | | | | | The hardware support does not seem to work with qemu. The support can be enabled with ifconfig or via ioctl on real hardware to get the performance boost. | ||||
* | Update LibBSD doco. | Chris Johns | 2015-06-01 | 1 | -108/+115 |
* | SLEEPQUEUE(9): Port to RTEMS | Sebastian Huber | 2015-03-24 | 1 | -0/+2 |
* | Add and use rtems_bsd_get_allocator_domain_size() | Sebastian Huber | 2015-02-13 | 1 | -0/+8 |
* | Add and use rtems_bsd_get_task_stack_size() | Sebastian Huber | 2015-01-20 | 1 | -0/+4 |
* | Add and use rtems_bsd_get_task_priority() | Sebastian Huber | 2015-01-20 | 1 | -0/+8 |
* | HOSTNAME(1): Add -m flag | Sebastian Huber | 2014-11-20 | 1 | -0/+9 |
* | doc: Add network interface link up/down hint | Sebastian Huber | 2014-10-16 | 1 | -0/+11 |
* | doc: Clarify initialization | Sebastian Huber | 2014-05-16 | 1 | -7/+51 |
* | doc: Clarify test run | Sebastian Huber | 2014-05-16 | 1 | -0/+16 |
