* | libbsd: Remove sys/select.h and sys/_sigset.h. | Chris Johns | 2016-04-27 | 1 | -2/+0 |
* | Add root bus support functions | Sebastian Huber | 2016-04-26 | 1 | -0/+1 |
* | Initialize interrupt server early | Sebastian Huber | 2016-04-26 | 1 | -0/+1 |
| | | | | This enables its use before the Nexus device exists. | ||||
* | Add RTEMS version support, update all python to 2 and 3. | Chris Johns | 2016-04-18 | 1 | -1/+7 |
| | | | | | | | | | | | | | Add support to force the RTEMS version. This remove the need for using the --rtems-version command line option if the automatic detection fails. Update all python code to support python 2 and 3. Update rtems_waf to the latest version to support the RTEMS version, check environment variables and to display the CC version. Sort all tests. I think the unsorted list is dependent on the version of python and so would result in repo noise as if it regenerted. | ||||
* | Use RTEMS provided <sys/priority.h> | Sebastian Huber | 2015-11-17 | 1 | -1/+0 |
* | Use RTEMS provided <sys/ttycom.h> | Sebastian Huber | 2015-11-17 | 1 | -1/+0 |
* | Use RTEMS provided <sys/sockio.h> | Sebastian Huber | 2015-11-17 | 1 | -1/+0 |
* | Use RTEMS provided <sys/mman.h> | Sebastian Huber | 2015-11-17 | 1 | -2/+0 |
* | Use RTEMS provided <sys/endian.h> | Sebastian Huber | 2015-11-17 | 1 | -1/+0 |
* | dwc_otg: Port to RTEMS | Sebastian Huber | 2015-11-12 | 1 | -0/+4 |
* | BUS_SPACE(9): Use FreeBSD files for i386 arch | Sebastian Huber | 2015-09-29 | 1 | -0/+2 |
* | Avoid pci_cfgreg.h rename | Sebastian Huber | 2015-09-29 | 1 | -8/+2 |
* | builder.py: addTargetSourceCPUDependentSourceFiles | Sebastian Huber | 2015-09-25 | 1 | -25/+12 |
| | | | | Avoid and delete this function. | ||||
* | Avoid pci_bus.c file rename | Sebastian Huber | 2015-09-25 | 1 | -8/+1 |
* | Delete superfluous pci_cfgreg.h files | Sebastian Huber | 2015-09-01 | 1 | -2/+1 |
* | Delete superfluous legacyvar.h files | Sebastian Huber | 2015-09-01 | 1 | -8/+0 |
* | Delete superfluous pci_bus.c files | Sebastian Huber | 2015-09-01 | 1 | -2/+1 |
* | Delete superfluous legacy.c files | Sebastian Huber | 2015-09-01 | 1 | -9/+0 |
* | e1000: Add missing file | Sebastian Huber | 2015-07-31 | 1 | -11/+12 |
* | TCPDUMP and PCAP fixes to defines. | Chris Johns | 2015-06-16 | 1 | -3/+11 |
* | Add tcpdump and libpcap. | Chris Johns | 2015-06-15 | 1 | -3/+321 |
| | | | | | | | | | - Update the file builder generator to handle generator specific cflags and includes. The tcpdump and libpcap have localised headers and need specific headers paths to see them. There are also module specific flags and these need to be passed to the lex and yacc generators. - Add the tcpdump support. | ||||
* | Add INVARIANTS support | Sebastian Huber | 2015-05-20 | 1 | -0/+1 |
* | Update due to API changes (timecounters) | Sebastian Huber | 2015-05-20 | 1 | -3/+0 |
* | usb: Import USB support from libusb | Sebastian Huber | 2015-05-15 | 1 | -2/+3 |
* | Disable IEEE 802.11 module | Sebastian Huber | 2015-05-15 | 1 | -1/+1 |
* | freebsd-to-rtems: Refactor the conversion support to allow multiples build ↵ | Chris Johns | 2015-05-15 | 1 | -0/+2300 |
systems. Split the freebsd-to-rtems.py into separate parts to allow more than a single build system generator. |
