* | Add support to build using waf. | Chris Johns | 2015-05-20 | 1 | -5/+9 |
* | freebsd-to-rtems: Refactor the conversion support to allow multiples build ↵ | Chris Johns | 2015-05-15 | 1 | -2592/+81 |
| | | | | | | | systems. Split the freebsd-to-rtems.py into separate parts to allow more than a single build system generator. | ||||
* | mghttpd: Import from RTEMS | Sebastian Huber | 2015-04-08 | 1 | -0/+9 |
* | Add generated files | Sebastian Huber | 2015-04-08 | 1 | -8/+4 |
| | | | | | | This avoids dependencies on a particular generator tool version. On MinGW and Cygwin hosts these tools tend to be outdated or somehow incapable. | ||||
* | if_dwc: Import from FreeBSD | Sebastian Huber | 2015-04-01 | 1 | -0/+2 |
* | mii: Add phy devices | Sebastian Huber | 2015-04-01 | 1 | -0/+3 |
* | LAGG(4): Enable and test | Sebastian Huber | 2015-03-30 | 1 | -0/+1 |
* | VLAN(4): Enable and test | Sebastian Huber | 2015-03-30 | 1 | -1/+2 |
* | media01: New test | Sebastian Huber | 2015-03-26 | 1 | -0/+1 |
* | mmc: Import MMC/SDCard support from libusb | Sebastian Huber | 2015-03-26 | 1 | -0/+23 |
* | smp01: New test | Sebastian Huber | 2015-03-24 | 1 | -0/+1 |
* | CONDVAR(9): Use FreeBSD implementation | Sebastian Huber | 2015-03-24 | 1 | -1/+1 |
* | SLEEPQUEUE(9): Port to RTEMS | Sebastian Huber | 2015-03-24 | 1 | -0/+2 |
* | SLEEP(9): Port to RTEMS | Sebastian Huber | 2015-03-24 | 1 | -1/+1 |
* | Update due to Newlib <sys/time.h> etc. changes | Sebastian Huber | 2015-03-24 | 1 | -2/+0 |
* | Special case for <rtems/bsd/zerocopy.h> | Sebastian Huber | 2015-03-24 | 1 | -0/+1 |
* | Use C11 and C++11 | Sebastian Huber | 2015-03-06 | 1 | -1/+2 |
| | | | | This is necessary to use <stdatomic.h> and <atomic>. | ||||
* | Add zerocopy sendto | Sebastian Huber | 2015-02-13 | 1 | -0/+2 |
* | freebsd-to-rtems.py: Fix revert includes | Sebastian Huber | 2015-02-13 | 1 | -0/+2 |
* | freebsd-to-rtems.py: Change default directories | Sebastian Huber | 2015-02-13 | 1 | -4/+4 |
* | if_tsec: Add Nexus support | Sebastian Huber | 2015-02-13 | 1 | -0/+1 |
* | Add and use rtems_bsd_get_allocator_domain_size() | Sebastian Huber | 2015-02-13 | 1 | -0/+1 |
* | Add a simple page allocator | Sebastian Huber | 2015-01-29 | 1 | -0/+1 |
* | zy7_slcr: Import from FreeBSD | Sebastian Huber | 2015-01-21 | 1 | -0/+2 |
* | e1000phy: Import from FreeBSD | Sebastian Huber | 2015-01-21 | 1 | -0/+2 |
* | if_cgem: Import from FreeBSD | Sebastian Huber | 2015-01-21 | 1 | -0/+2 |
* | Add rtems_bsd_get_mac_address() | Sebastian Huber | 2015-01-21 | 1 | -0/+1 |
* | Add and use rtems_bsd_get_task_stack_size() | Sebastian Huber | 2015-01-20 | 1 | -0/+1 |
* | Add and use rtems_bsd_get_task_priority() | Sebastian Huber | 2015-01-20 | 1 | -0/+1 |
* | Add rtems_mdns_gethostname() | Sebastian Huber | 2014-11-10 | 1 | -1/+1 |
* | Add rtems_mdns_sethostname() | Sebastian Huber | 2014-11-06 | 1 | -0/+1 |
| | | | | | Use it to set the multi-cast hostname of the default mDNS resolver instance via sethostname(). | ||||
* | HOSTNAME(1): Import from FreeBSD | Sebastian Huber | 2014-11-05 | 1 | -0/+1 |
* | Add mDNS support for name service dispatcher | Sebastian Huber | 2014-11-04 | 1 | -0/+1 |
* | Support sethostname() and gethostname() | Sebastian Huber | 2014-10-24 | 1 | -0/+1 |
* | ppp: Port to new stack | Sebastian Huber | 2014-10-08 | 1 | -0/+20 |
* | nexus: Use a linker set for the devices | Sebastian Huber | 2014-10-08 | 1 | -1/+0 |
* | Provide new rtems_bsdnet_rtrequest() | Sebastian Huber | 2014-10-08 | 1 | -1/+1 |
| | | | | Delete superfluous code. | ||||
* | Makefile: Remove superfluous include path | Sebastian Huber | 2014-10-08 | 1 | -1/+0 |
* | critical_enter/exit(): Use inline function | Sebastian Huber | 2014-09-30 | 1 | -1/+0 |
* | rtems_bsd_mutex: Optimize | Sebastian Huber | 2014-09-24 | 1 | -0/+1 |
* | Replace RTEMS objects with custom implementation | Sebastian Huber | 2014-09-23 | 1 | -0/+2 |
| | | | | | | | | Performance analysis revealed that the standard RTEMS objects are a major bottleneck. The object get mechanism and attribute checks at runtime have a significant overhead. Use a custom implementation for synchronization primitives. This drops also the size of the synchronization primitives considerably. | ||||
* | Disable IPsec | Sebastian Huber | 2014-09-23 | 1 | -3/+3 |
| | | | | | IPsec has a significant performance impact. Disable it for now since is only partially supported and untested. | ||||
* | Import and use subr_lock.c | Sebastian Huber | 2014-09-22 | 1 | -1/+1 |
* | Install missing header files | Sebastian Huber | 2014-09-22 | 1 | -0/+3 |
* | Makefile: Add -fno-strict-aliasing | Sebastian Huber | 2014-09-18 | 1 | -0/+1 |
* | telnetd01: New test | Sebastian Huber | 2014-09-18 | 1 | -0/+1 |
* | telnetd: Import from RTEMS sources | Sebastian Huber | 2014-09-18 | 1 | -0/+4 |
* | Add file to ensure some C++ compatibility | Sebastian Huber | 2014-09-17 | 1 | -27/+31 |
* | Install missing header files | Sebastian Huber | 2014-08-28 | 1 | -1/+4 |
* | Fix library creation | Sebastian Huber | 2014-08-28 | 1 | -0/+1 |
| | | | | | Delete library and create it from scratch to avoid problems with non-unique file names. |
