* | Build System: Add option to disable IPV6 in orderly fashion | Joel Sherrill | 2012-08-31 | 1 | -1/+2 |
| | | | | | | | If you define DISABLE_IPV6=yes to the config.inc, then the rtems-bsd-config.h file will be modified accordingly and the IPV6 kernel sources will not be built. This is easier to manage and more correct than having a patch to do the same. | ||||
* | Use paths based off of $HOME so easier to replicate for others | Joel Sherrill | 2012-03-08 | 1 | -2/+2 |
* | Use RTEMS installed in newbsd working tree | Joel Sherrill | 2012-03-07 | 1 | -1/+1 |
* | Separate User Path Settings Into New File config.inc | Joel Sherrill | 2012-03-07 | 1 | -0/+3 |
This makes the settings available for use in other Makefiles. Specifically when tests are added. |
