* | spec: Add spec for rtems_timer_server_fire_when() | Frank Kühndel | 2021-05-17 | 1 | -0/+1267 |
| | | | | | | Adding a specification item to rtems-central for the directive rtems_timer_server_fire_when() of the timer manager. This item uses the timer specific glossary terms, too. | ||||
* | spec: Add spec for rtems_timer_server_fire_after() | Frank Kühndel | 2021-05-17 | 1 | -0/+965 |
| | | | | | | Adding a specification item to rtems-central for the directive rtems_timer_server_fire_after() of the timer manager. This item uses the timer specific glossary terms, too. | ||||
* | spec: Add spec item for rtems_timer_fire_when() | Frank Kühndel | 2021-05-17 | 1 | -0/+1103 |
| | | | | | | Adding a specification item to rtems-central for the directive rtems_timer_fire_when() of the timer manager. This item uses the timer specific glossary terms, too. | ||||
* | spec: timer: Unset clock after test | Frank Kühndel | 2021-05-17 | 3 | -5/+11 |
| | | | | | | | | | | This patch changes rtems_timer_cancel(), rtems_timer_reset() and rtems_timer_fire_after() validation tests. It adds a call to UnsetClock() in teardown to set the state of the system back to where is was before the test. In addition, in rtems_timer_fire_after() it fixes a typo in pre-condition requirements. | ||||
* | spec: Add spec item for rtems_timer_fire_after() | Frank Kühndel | 2021-05-17 | 1 | -0/+857 |
| | | | | | | Adding a specification item to rtems-central for the directive rtems_timer_fire_after() of the timer manager. This item uses the timer specific glossary terms, too. | ||||
* | spec: Add spec item for rtems_timer_reset() | Frank Kühndel | 2021-05-17 | 1 | -0/+741 |
| | | | | | | Adding the specification item to rtems-central for the directive rtems_timer_reset() of the timer manager. This item uses the timer specific glossary terms, too. | ||||
* | spec: rtems_timer_cancel() use new glossary terms | Frank Kühndel | 2021-05-17 | 1 | -65/+45 |
| | | | | | This patch changes the requirements texts of the specification of rtems_timer_cancel() to use the new glossary terms. | ||||
* | spec: Glossary terms for timer manager | Frank Kühndel | 2021-05-17 | 15 | -0/+282 |
| | | | | | | | | | | | | | | spec/rtems/timer/glossary/*.yml Here are the timer specific glossary terms. As requested, the manager specific terms are put into an own folder alongside the other specification files of the manager. spec/glossary-requirements.yml The glossary terms for specifications are in an own group *glossary-requirements* to keep them separate from the existing glossary terms (*glossary-general*). | ||||
* | spec: Add spec item for rtems_timer_cancel() | Frank Kühndel | 2021-05-14 | 1 | -0/+521 |
| | | | | | Adding the specification item to rtems-central for the directive rtems_timer_cancel() of the timer manager. | ||||
* | spec: timer_initiate_server test more independent | Frank Kühndel | 2021-05-14 | 1 | -6/+10 |
| | | | | | | Factoring out the direct use of _Timer_server. The access to RTEMS internals should be bundled in one place and not spread over many files in the validation tests. | ||||
* | spec: rtems_timer_initiate_server() minor changes | Frank Kühndel | 2021-05-14 | 1 | -18/+17 |
| | | | | | Apply recommended changes from review to specification item for rtems_timer_initiate_server(). | ||||
* | spec: Fix rtems_scheduler_ident() validation | Sebastian Huber | 2021-05-14 | 1 | -1/+0 |
* | spec: Move INVALID_ID to tx-support.h | Sebastian Huber | 2021-05-14 | 17 | -47/+28 |
* | spec: Constify rtems_task_wake_when() | Sebastian Huber | 2021-05-12 | 1 | -1/+1 |
* | spec: Clarify rtems_task_get_priority() doc | Sebastian Huber | 2021-05-12 | 1 | -2/+2 |
* | spec: Document rtems_task_set_scheduler() errors | Sebastian Huber | 2021-05-12 | 1 | -2/+26 |
* | spec: rtems_scheduler_get_processor_maximum() | Sebastian Huber | 2021-05-10 | 1 | -0/+182 |
* | applconfig: Use unspecified groups | Sebastian Huber | 2021-05-07 | 54 | -53/+221 |
| | | | | Remove ${.:document-reference/*} hacks. | ||||
* | applconfig: Use unspecified groups | Sebastian Huber | 2021-05-07 | 11 | -9/+25 |
* | applconfig: Use unspecified function | Sebastian Huber | 2021-05-07 | 2 | -1/+14 |
* | spec: Fix links | Sebastian Huber | 2021-05-07 | 2 | -2/+2 |
* | spec: Fix links | Sebastian Huber | 2021-05-07 | 2 | -4/+4 |
* | spec: Fix rtems_scheduler_get_processor() vali | Sebastian Huber | 2021-05-07 | 1 | -1/+2 |
* | spec: Specify scheduler manager directives | Sebastian Huber | 2021-05-07 | 13 | -1/+2062 |
* | spec: Add SMP-only and non-SMP test suites | Sebastian Huber | 2021-05-07 | 2 | -0/+47 |
* | spec: Update scheduler documentation | Sebastian Huber | 2021-05-07 | 2 | -1/+4 |
* | spec: Specify memory allocation directives | Sebastian Huber | 2021-05-07 | 9 | -0/+718 |
* | spec: Fix semaphore set priority validation | Sebastian Huber | 2021-05-07 | 1 | -0/+4 |
* | spec: Fix ceiling enqueue validation | Sebastian Huber | 2021-05-06 | 2 | -7/+10 |
* | spec: Avoid name conflicts with test support | Sebastian Huber | 2021-05-06 | 2 | -13/+13 |
* | spec: Add RTEMS_NOINIT | Sebastian Huber | 2021-05-02 | 1 | -0/+22 |
* | spec: Add requirements for acfg | Sebastian Huber | 2021-04-29 | 305 | -157/+2633 |
* | spec: Replace constraint scope with a link | Sebastian Huber | 2021-04-29 | 101 | -202/+311 |
* | spec: Add requirement for test suites | Sebastian Huber | 2021-04-29 | 7 | -6/+32 |
* | spec: Add test suite name attribute | Sebastian Huber | 2021-04-29 | 29 | -6/+38 |
* | spec: Link general glossary to to root requirement | Sebastian Huber | 2021-04-29 | 2 | -13/+1 |
* | spec: Add unit test role | Sebastian Huber | 2021-04-29 | 3 | -2/+36 |
* | spec: Add requirement for interface domains | Sebastian Huber | 2021-04-29 | 8 | -9/+38 |
* | spec: Use explicit constraints for acfg | Sebastian Huber | 2021-04-29 | 138 | -487/+812 |
* | spec: Fix CONFIGURE_BSP_PREREQUISITE_DRIVERS docs | Sebastian Huber | 2021-04-29 | 1 | -2/+2 |
* | spec: Add missing "the" | Sebastian Huber | 2021-04-29 | 9 | -10/+10 |
* | spec: Fix wording | Sebastian Huber | 2021-04-29 | 1 | -1/+0 |
* | spec: Update /rtems/region/* documentation | Sebastian Huber | 2021-04-28 | 10 | -75/+394 |
* | spec: Update /rtems/task/* documentation | Sebastian Huber | 2021-04-28 | 41 | -159/+849 |
* | spec: Generalize may preempt constraints | Sebastian Huber | 2021-04-28 | 2 | -3/+4 |
* | spec: Allow multiple interface references | Sebastian Huber | 2021-04-28 | 200 | -204/+245 |
* | spec: Update /rtems/scheduler/* documentation | Sebastian Huber | 2021-04-27 | 14 | -79/+209 |
* | spec: Update /rtems/intr/* documentation | Sebastian Huber | 2021-04-27 | 33 | -147/+618 |
* | spec: Constify timer fire when directives | Sebastian Huber | 2021-04-27 | 2 | -2/+2 |
* | spec: Use glossary term | Sebastian Huber | 2021-04-27 | 1 | -3/+3 |
