* | spec: Improve documentation | Sebastian Huber | 2021-02-26 | 1 | -1/+1 |
* | spec: Add build label and target hash directives | Sebastian Huber | 2021-02-26 | 2 | -0/+81 |
* | spec: Improve wording | Sebastian Huber | 2021-02-26 | 1 | -10/+10 |
* | spec: Harmonize create directives | Sebastian Huber | 2021-02-25 | 4 | -133/+261 |
* | spec: Remove unused state | Sebastian Huber | 2021-02-25 | 1 | -6/+0 |
* | spec: Remove superfluous includes | Sebastian Huber | 2021-02-22 | 3 | -6/+0 |
* | spec: Simplify partition create validation | Sebastian Huber | 2021-02-21 | 1 | -55/+43 |
* | spec: Simplify barrier create validation | Sebastian Huber | 2021-02-21 | 1 | -37/+14 |
* | spec: Simplify message queue construct validation | Sebastian Huber | 2021-02-21 | 1 | -70/+46 |
* | spec: Fix partition create | Sebastian Huber | 2021-02-20 | 1 | -3/+2 |
* | spec: Specify rtems_task_mode() | Sebastian Huber | 2021-02-20 | 3 | -10/+138 |
* | spec: Move rtems_task_priority item | Sebastian Huber | 2021-02-19 | 15 | -18/+19 |
* | spec: Specify missing barrier create case | Sebastian Huber | 2021-02-19 | 1 | -3/+101 |
* | spec: Harmonize partition create | Sebastian Huber | 2021-02-19 | 1 | -69/+111 |
* | spec: Use EARS syntax | Sebastian Huber | 2021-02-19 | 10 | -27/+31 |
| | | | | Avoid the term "There shall". | ||||
* | spec: Fix wording | Sebastian Huber | 2021-02-19 | 1 | -1/+1 |
* | spec: Specify signal manager | Sebastian Huber | 2021-02-19 | 2 | -0/+1629 |
* | spec: Document signal manager | Sebastian Huber | 2021-02-19 | 37 | -51/+177 |
* | spec: Add test suite | Sebastian Huber | 2021-02-19 | 3 | -4/+26 |
* | spec: Specify RTEMS_ALIGNOF() | Sebastian Huber | 2021-02-19 | 1 | -0/+38 |
* | spec: Fix clock manager parameter names | Sebastian Huber | 2021-02-17 | 2 | -5/+5 |
* | spec: Use EARS syntax | Sebastian Huber | 2021-02-17 | 35 | -112/+114 |
* | spec: Document clock manager | Sebastian Huber | 2021-02-17 | 18 | -81/+337 |
* | spec: Fix clock interface placement order | Sebastian Huber | 2021-02-17 | 4 | -1/+31 |
* | spec: Fix barrier specification | Sebastian Huber | 2021-02-17 | 3 | -13/+13 |
* | spec: Add constraints to create/delete | Sebastian Huber | 2021-02-10 | 11 | -0/+55 |
* | spec: Add constraints to semaphore manager | Sebastian Huber | 2021-02-10 | 13 | -9/+123 |
* | spec: Document missing parameter | Sebastian Huber | 2021-02-10 | 1 | -0/+1 |
* | spec: Rename constraint | Sebastian Huber | 2021-02-10 | 5 | -5/+5 |
* | spec: Fix references | Sebastian Huber | 2021-02-08 | 4 | -4/+4 |
* | spec: Specify barrier manager | Sebastian Huber | 2021-02-08 | 4 | -0/+1343 |
* | spec: Tweak construct errors | Sebastian Huber | 2021-02-08 | 2 | -34/+47 |
* | spec: Specify rtems_build_name() | Sebastian Huber | 2021-02-08 | 2 | -0/+110 |
* | spec: Document barrier directives | Sebastian Huber | 2021-02-04 | 3 | -15/+84 |
* | spec: Document semaphore directives | Sebastian Huber | 2021-02-04 | 6 | -33/+434 |
* | spec: Use constraints for event manager | Sebastian Huber | 2021-02-04 | 7 | -3/+48 |
* | spec: Improve wording | Sebastian Huber | 2021-02-04 | 1 | -2/+1 |
* | spec: Rename test case action attributes | Sebastian Huber | 2021-02-04 | 20 | -859/+859 |
| | | | | The new attribute keys make it easier to write test cases. | ||||
* | validation: Move actions to separate functions | Sebastian Huber | 2021-02-04 | 8 | -25/+86 |
* | validation: Remove prologue/epilogue in test cases | Sebastian Huber | 2021-02-04 | 19 | -49/+0 |
* | spec: Use quoted string for string with tabs | Sebastian Huber | 2021-02-04 | 1 | -12/+6 |
* | spec: Remove comments | Sebastian Huber | 2021-02-04 | 1 | -159/+0 |
* | spec: Avoid test prologue/epilogue in test cases | Sebastian Huber | 2021-02-04 | 15 | -137/+172 |
* | validation: Add context and fixture to test case | Sebastian Huber | 2021-02-04 | 19 | -24/+108 |
* | spec: Document all delete directives | Sebastian Huber | 2021-02-03 | 10 | -74/+338 |
* | spec: Document all create directives | Sebastian Huber | 2021-02-03 | 21 | -245/+961 |
* | spec: Use constraints for partition manager | Sebastian Huber | 2021-02-03 | 2 | -11/+19 |
* | spec: Use constraints for timer manager | Sebastian Huber | 2021-02-03 | 8 | -21/+75 |
* | spec: Clarify object identification | Sebastian Huber | 2021-02-03 | 11 | -68/+154 |
* | spec: Clarify rtems_event_receive() | Sebastian Huber | 2021-02-03 | 1 | -14/+19 |
