2000-04-13 | Changed version to 4.5.0-beta2.netdemos-4-5-0-beta2netdemos-4-5-branch | Joel Sherrill | |
2000-04-03 | Changed port number from 80 (http) to 21 (ftp) after report from | Joel Sherrill | |
Chris Johns <ccj@acm.org>. | |||
2000-03-24 | Added instructions on running ttcp from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | |
2000-02-11 | Changed version to 4.5.0-beta1b.netdemos-4-5-0-beta1b | Joel Sherrill | |
2000-01-04 | This commit was manufactured by cvs2svn to create branch | cvs2git | |
'netdemos-4-5-branch'. Sprout from master 2000-01-04 16:25:57 UTC Joel Sherrill <joel.sherrill@OARcorp.com> 'Changed version to 20000104.' Cherrypick from ERIC-NORUM 1998-07-30 14:42:29 UTC Joel Sherrill <joel.sherrill@OARcorp.com> 'base from Eric Norum -- Demos.30May1998.tar.gz': ttcp/ttcp_orig/ttcp.1 | |||
2000-01-04 | Changed version to 20000104. | Joel Sherrill | |
1999-12-14 | Changed CONFIGURATION_MICROSECONDS_PER_TICK definition to a more reasonable | Joel Sherrill | |
value. | |||
1999-11-16 | Changed version to 19991116. | Joel Sherrill | |
1999-11-16 | Cleaned up to make it a bit easier to generate sizes. | Joel Sherrill | |
1999-11-12 | New test to determine network application sizes. | Joel Sherrill | |
1999-11-10 | Patch from Eric Norum <eric@cls.usask.ca> to add the new fields to | Joel Sherrill | |
the network configuration example. | |||
1999-11-10 | New ntp demo test from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | |
1999-10-28 | Changed version to 19991028. | Joel Sherrill | |
1999-10-28 | New httpd sample test from Emmanuel Raguet. | Joel Sherrill | |
1999-08-20 | Changed version to 19990820. | Joel Sherrill | |
1999-07-12 | Patch from Eric Norum <eric@cls.usask.ca>: | Joel Sherrill | |
I changed the TFTP test program and TFTP driver to reflect the changes in the way paths are passed to the TFTP driver. The TFTP driver now needs a proper `dotted-decimal' hostname as the second component of the path name. | |||
1999-07-09 | Changed version to 199900709. | Joel Sherrill | |
1999-06-11 | Patch from Ian Lance Taylor <ian@airs.com> to test new "interrupt-ish" | Joel Sherrill | |
driven select on socket support. After the patch to RTEMS, I have appended a patch to netdemos-19990407/select/test.c to test the new functionality and demonstrate one way it might be used. To run the new test instead of the select test, change doSocket to call echoServer2 instead of echoServer. | |||
1999-06-11 | Updated. | Joel Sherrill | |
1999-04-07 | Changed to bogus information. | Joel Sherrill | |
1999-04-01 | Patch from Eric Norum <eric@skatter.usask.ca> to take advantage of new | Joel Sherrill | |
routines in RTEMS. | |||
1999-02-10 | Added debug print when test can't get a buffer. This is probably a fatal | Joel Sherrill | |
error in the stack but it would be nice to get a message from the test just in case. | |||
1999-02-10 | Modified to delay at startup. | Joel Sherrill | |
1999-02-10 | Modified to support TFTP filesystem. | Joel Sherrill | |
1999-02-10 | Added call to rtems_bsdnet_show_inet_routes(). | Joel Sherrill | |
1999-02-10 | Removed warnings. | Joel Sherrill | |
1999-02-10 | Modified so warnings would be printed if no network driver was defined. | Joel Sherrill | |
1999-02-10 | Removing socket test. | Joel Sherrill | |
1998-12-17 | changed version to 19981217 | Joel Sherrill | |
1998-12-14 | New files from Eric Norum to test the select code. | Joel Sherrill | |
1998-10-27 | changed version to 4.0.0 | Joel Sherrill | |
1998-10-15 | changed version to 4.0.0-beta4a | Joel Sherrill | |
1998-10-13 | Changed to clarify how to set the network address. | Joel Sherrill | |
1998-08-21 | Removed reference to TRACE_NETWORK_DRIVER which was KA9Q specific. | Joel Sherrill | |
1998-08-21 | changed version to 980821 | Joel Sherrill | |
1998-08-21 | changed version to 980326 | Joel Sherrill | |
1998-08-21 | New file | Joel Sherrill | |
1998-08-21 | Added CVS Id Strings which were missing | Joel Sherrill | |
1998-08-21 | KA9Q -> FreeBSD changes from Eric Norum | Joel Sherrill | |
1998-08-21 | Removed -- now provided by RTEMS | Joel Sherrill | |
1998-08-21 | New files | Joel Sherrill | |
1998-08-12 | Added gratuitous arp and commented out a confusing printf. | Joel Sherrill | |
1998-08-12 | Added foreground task which can print KA9Q tables. | Joel Sherrill | |
1998-08-12 | Added CVS Id. | Joel Sherrill | |
1998-08-12 | Added support for non-bootp servers | Joel Sherrill | |
1998-08-12 | Cleaned up USE_BOOTP conditional for initialization. | Joel Sherrill | |
Get info from usercfg.h now. Added message indicating test is exitting. | |||
1998-08-12 | Added info on telnet servers needed by netdemo. | Joel Sherrill | |
Added info on tftp server for non-bootp systems. | |||
1998-08-12 | Added undef of delay to avoid errors on some targets. | Joel Sherrill | |
1998-08-12 | Added code to turn on debug. | Joel Sherrill | |
1998-08-11 | new file | Joel Sherrill | |
